ideas with fitting charger (M30B35 build)
Driftben
Sun Apr 05, 2009 11:31 pm
no i would think that its easier to get better power figures through a turbo conversion but for more usable power i would go for a S/C conversion providing its done well.
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
DRIFTBOY
Mon Apr 06, 2009 12:23 am
STiBen wrote:only problem iv come across is trying to get the main nut off the end of the crank so i can change the timing chain and tensioner. i just cant keep the bugger from moving while i try the undo it. iv even tried adding beer to the pa-lava.
any ideas on this?
More beer! :D
Seriously, I've had big trouble with these!
Twice now I've drilled and grinded into them and then split them with a hammer and chisel!
That was after I wedged the flywheel with my biggest pry bar and used a length of exhaust on top of my biggest breaker bar on the pulley nut, and I bent the pry bar like a bannana! 8O
Not a nice job, and you need to take care to not damage the crankshaft, but a new nut and washer is only about £5 from BMW.
Nice work there though! 8)
Driftben
Mon Apr 06, 2009 8:41 am
Sounds like a grinder and some carnage + beer once iv finished with the power tools. Safety first.
Need to pop down BMW anyway to grab a water pump gasket and sump gasket so could pick one up then. Any idea on the part number?
Cheers 8)
6pot wilwoods front
4pot Porsche rear
winx
Mon Apr 06, 2009 1:12 pm
last week we put a pry bar in the teeth of the flywheel and held it against the block. Tried with an air gun but wouldnt move! Switched the air gun over and sent the other way for a second then reversed and it came straight off!
DRIFTBOY
Mon Apr 06, 2009 1:49 pm
STiBen wrote:. Any idea on the part number?
Nut - 11231253339
Washer - 07119932190
Driftben
Mon Apr 06, 2009 10:47 pm
I'll have a go with a mighty pry bar but I don't have a air gun :( need to get my arse in the 20th century.
I took the sump off today to replace the gasket, is there anything I could check before I put the sump back on? Maybe if the bearings are scored or something.
Also I got told that I should get my pistons skimmed or replaced with low comp ones. Any ideas on this? I'll be hoping for About 1 bar boost from the charger.
Cheers for the part numbers driftboy I'll most probably need that.
6pot wilwoods front
4pot Porsche rear
DRIFTBOY
Tue Apr 07, 2009 2:28 am
STiBen wrote:I'll have a go with a mighty pry bar but I don't have a air gun :( need to get my arse in the 20th century. .
Good luck with that... :?
I'd love to have air tools too but no space at all for a compressor. :(
STiBen wrote:I took the sump off today to replace the gasket, is there anything I could check before I put the sump back on? Maybe if the bearings are scored or something. .
I would, partly out of curiosity.
And it's best to know now if there's a problem rather than find out later!
If you do get the timing gear off you could also take the oil pump apart and inspect / measure that, it's not that difficult.
STiBen wrote:Also I got told that I should get my pistons skimmed or replaced with low comp ones. Any ideas on this? I'll be hoping for About 1 bar boost from the charger. .
Piston skimming is a little risky if you take it too far, as it weakens the cast piston.
I have an M30 piston which I cut in half, so if you need to know thicknesses or anything just let me know.
It might be worth doing a search on t'internet to find out how much boost the standard / skimmed cast pistons can handle, forged ones would be nice and strong, but expensive I'd guess! :?
I might look into this myself, when I'm soberer! :roll:
baptie0
Tue Apr 07, 2009 2:42 am
you could also put a decompression plate on it. i have a 2mm one on my m50 turbo, no problems so far.
Driftben
Tue Apr 07, 2009 8:41 am
Hmmmm the big £££ seem to come to light.
Maybe I should go for a set of forge pistions. Can I keep the same H rods or should I replace them too.
Is a decommpression plate just a thinner head gasket? I was advised against them probably because the bloke wants to charge me for the pistions as well the bugger.
Driftboy if you could measure the thickness in the centre of the piston that would be a great help. I got told they wasn't very thick.
6pot wilwoods front
4pot Porsche rear
DRIFTBOY
Tue Apr 07, 2009 1:56 pm
In the centre of the crown, it's thinnest point, it is 7.6mm thick.
Driftben
Tue Apr 07, 2009 2:24 pm
There's not really much I can take off before they get too weak then. Might have to be new pistons :cry: there goes my budget project.
Need research on a set of pistons.
6pot wilwoods front
4pot Porsche rear
Tue Apr 07, 2009 2:34 pm
That's sooo last century! :wink:
Driftben
Tue Apr 07, 2009 2:55 pm
Haha ya really I should be undoing it with my mind power. :cool:
6pot wilwoods front
4pot Porsche rear
Driftben
Thu Apr 09, 2009 9:51 pm
alittle update on progress
i brought a 318ti the other day to take the rear beam off. took some pics as im trying to get into the swing of things.
just wondering if there is anything else i can steal from the E36 318ti?
cheers
6pot wilwoods front
4pot Porsche rear
DRIFTBOY
Thu Apr 09, 2009 9:52 pm
Steering rack..?
Driftben
Thu Apr 09, 2009 10:12 pm
hmmm is that as good as the z3 rack?
6pot wilwoods front
4pot Porsche rear
DRIFTBOY
Thu Apr 09, 2009 10:13 pm
No, but it's still a good upgrade!
Driftben
Thu Apr 09, 2009 10:16 pm
whats the ratio on it? come on off the top your head the pressure is on :wink:
was thinking of having a z3 rack but if theres not much in it between the two ill take the E36 one.
6pot wilwoods front
4pot Porsche rear
DRIFTBOY
Thu Apr 09, 2009 10:22 pm
I must admit I don't know from memory the ratios.
I just did a search for ' z3 and rack and ratio ', it brought up loads of threads, could be worth a quick read.
I would but I'm just about to go to the pub! :cheers:
Driftben
Thu Apr 09, 2009 10:36 pm
well i must admit the pub does sound mighty good right now....
ill have a quick read cheers driftboy 8)
6pot wilwoods front
4pot Porsche rear
gareth
Fri Apr 10, 2009 11:43 am
nice project you've got :D
you might end up having to make a custom radiator though. on my conversion (10mm forwards of position 3) i had to cut the redundant aircon pulley section off the front pully asssembly, just to clear the (thinner E28 535i) radiator. There is absolutely no room for another pulley.
Alpina used a rad, squeezed into the front panel for a while Image
also, with your S/C on the manifold like that, you'll have to move the servo and M/C under the dash?
gareth
Fri Apr 10, 2009 11:45 am
just noticed the angle of the alternator in that pic!!!!!!!!!!!! :eek: :mad: :mad:
Driftben
Fri Apr 10, 2009 5:22 pm
Cheers Gaz.
Iv just ordered my front and rear porche brakes so that will be next.
I'll hopefully be going to the position 3 so should have a incy bit more room. (I hope) I need to fit the charger pulley on the front so will next extra room anyway. Might be a pain but I'll try and get over it. Bit of A update later.
6pot wilwoods front
4pot Porsche rear
Driftben
Fri Apr 10, 2009 5:23 pm
Oh and the angle on the alternator is crazy. 8O
6pot wilwoods front
4pot Porsche rear
Driftben
Fri Apr 10, 2009 6:12 pm
Just a quicky before I scrap the 318ti does anything from the front suspension fit the e30?
6pot wilwoods front
4pot Porsche rear
Driftben
Wed Apr 15, 2009 11:32 am
Iv done a search round and I'm going ahead and getting a set of low comp. Forge pistons made. Just wondering on what spec and measurements I should go for as if never changed or got a set made before. (abit of a new one for me)
I'm hoping for making about 1bar boost from the charger. I'm also going for a intercooler as well if that helps.
The head is going for port and polishing and a skim so don't want a larger headgasket.
Ben
6pot wilwoods front
4pot Porsche rear
Francisco
Wed Apr 15, 2009 1:31 pm
check "downing atlanta" system. They use a similar Eaton charger bolted to the manifold and keep the pressure at around 0.7bar providing MORE than enough power without having to deal with intercooling piping and lower compression, etc. I'd keep it as simple as possible and just make sure you use someone who knows how to remap it on a rolling road with Knock sensors fitted during the job.
Driftben
Wed Apr 15, 2009 1:48 pm
Some good advice there. It would save me alot of money sticking with the standard compresion. Would it be wise though sticking with the intercooler ideas though? Keep charge temps down easier.
6pot wilwoods front
4pot Porsche rear
Francisco
Wed Apr 15, 2009 8:12 pm
On an M30 with it's huge safety margins and in British climate @ .7Bar the intercooling/piping will be giving you more weight, headaches and expense than benefits...
Driftben
Wed Apr 15, 2009 10:09 pm
i see. well that kind of changes everything.
back to the drawing board then, a very simpler one.
just need to change the big end bearings and pop the sump back on..... job done.
pop it in.
if its ever that easy.
6pot wilwoods front
4pot Porsche rear
DRIFTBOY
Wed Apr 15, 2009 10:20 pm
Only thing is, when you've got used to it with 7psi you WILL want more more more!
Then you'll need the intercooler!
Saab / Volvo intercoolers will fit behind the front panel with a few minor modifications and are dirt cheap from scrapyards, you can grab a load of hoses and pipes to plumb it in too, scrapheap challenge style! winkeye
My turbo uses a Volvo intercooler and boost pipes made from bits of Saab, Nissan and Ford, didn't cost much at all.
Driftben
Wed Apr 15, 2009 10:51 pm
see now thats the truth right there. id feel like i could blow more than 7 psi after a month.
not good.
iv seen some real good I/Cs on ebay for cheap too.
i might go as far as putting a nice I/C on. scrap the idea of low comp pistons.
a 740i twin turbo conversion sounds real good right now.
6pot wilwoods front
4pot Porsche rear
Driftben
Sun Aug 30, 2009 6:43 pm
ok abit of an update....
things have been abit slow as im trying to by a house at the same time. = banks are assholes.
anyway iv finally got my head back from being port and polished and its looking real good and tidy. iv also got over sized valves which have been ground in...
i now just needing a new cam and the heads complete.
im waiting on cotswold to sort my invoice out so i can buy all the gaskets, seals, bearings ect so i can finish the bottom end.
ps beefy you will get a pm about a set of mounts soonish winkeye
and one of my my over crowed garage (random)
6pot wilwoods front
4pot Porsche rear
DRIFTBOY
Mon Aug 31, 2009 3:26 am
Looks like an interesting build, what else are you planning on doing to it?
Good work so far. 8)
Driftben
Thu Sep 03, 2009 11:07 am
Well I'm having a everything new in the head, cam, uprated lifters, larger valves ect and i'm in the process of rebuilding the bottom end once Cotswold get back to me so I can order everything. Once the engine is rebuilt I can then start looking on how I can fit the supercharger.
The body is having alot of work done including 5 bolt hubs and Porsche brakes front and rear.
Still lots to do.
6pot wilwoods front
4pot Porsche rear
