noisy tappets on 325
e30max
Mon Apr 06, 2009 6:22 pm
Hi just bought my first e30 :-). Its a 325 and pulls really well however when the oil gets warm the tappets are quite loud is there anyway to quiten them down? any help appreciated. cheers!
FC_Touring
Mon Apr 06, 2009 7:09 pm
The M20 engine has mechanical tappets rather than hydraulic ones, so if they haven't been adjusted in a while they may be noisy.
My guess is checking the valve clearance and adjusting if necessary should solve the problem. Valve clearance should be set to 0.25mm with the engine cold iirc.
sam325is
Mon Apr 06, 2009 7:21 pm
The noise you are talking about is injectors.....maybe with a slight noise from the tappets. Adjust the tappets...but the noise wont go.
hongkongfuey
Mad-tango-geezer
Mon Apr 06, 2009 7:42 pm
1st don't overtighten tappets as they could snap the rockers.
2nd have you changed the oil lately???
with cars like mine,
e30max
Fri Apr 24, 2009 7:17 pm
sam325is wrote:The noise you are talking about is injectors.....maybe with a slight noise from the tappets. Adjust the tappets...but the noise wont go.
is this a common thing on 325's. ive changed the oil and filters and had the valves set to the right clearance but the noise is still there. are the injectors ment to make this noise? how do i make them quieter? or have they had it?
any advice? cheers.
