New M3
pony2
Post Sun Apr 05, 2009 4:50 pm
Some of you may remember this recently purchased car from a previous thread. The car has hardly been used in last few years. Although the previous owner maintained the car very well, I think it has suffered a bit from under use and lack of servicing more recently.
The first problem I had was overheating, after some very helpful advise on here it was apparent that a new fan and resistor were required. Problem fixed.
The engine still needs some attention and will soon be visiting a specialist for some much needed service.
The front jacking points are a bit crusty and need sorting, a bit of rust behind the fuse box and other small areas. Hope to be getting these sorted in the summer.
The rear bushes need replacing and I think new shock absorbers might help.
Before:
After:
I have cleaned the engine and changed the air filter (old one dated made in '93). Repaired a hole in the bottom of the air box as the metal mounting has rusted and vibration had caused the hole.
The interior is in good condition, I really do not like the steering wheel and think a smaller tech2 might be found to replace the old one.
SUMPCRACKER
Post Sun Apr 05, 2009 5:12 pm
Thats a realy nice car, whatever you spend its got to be worth it with the values soaring as they are.
Looks a lot better than most with those wheels.
Post Sun Apr 05, 2009 5:22 pm
Looks lovely. You cant beat genuine Alpina's.
jamie323i
Post Sun Apr 05, 2009 6:26 pm
That looks lovely,my 323i was left for a couple of years without any use,you will be surprised at the difference it makes just using it!
I now try to use it at least once a week. :D
Post Sun Apr 05, 2009 7:37 pm
Lovely M3, look's stunning :cool:
pony2
Post Sun Apr 05, 2009 8:34 pm
Thanks for the comments.
I really can't decide on the wheels, they do look really good with a silver car and 17" fill the arches. Just not sure how they perform compared to 16". The ride is pretty stiff which is what I'd expect on a m3, new bushes and shocks should improve things and then I might experiment with some alternative wheels.
Theo
Post Sun Apr 05, 2009 9:11 pm
Looks good, will be a nice car after some TLC.
I have a few bits which may be of interest to you - 16" BBS, smaller tech 2 wheel, correct shape gearknob, good nearside foglight.
zaust
Zone day release
Post Sun Apr 05, 2009 9:15 pm
Good plate too. (for astrix fans) As said already. Once it's back in tip top, use it once a week if you can.
M30 Tech 1 Touring on gas.
pony2
Post Sun Apr 05, 2009 9:16 pm
Theo, I did try and pm you about the steering wheel a few days ago, price?
What does the correct gearknob look like?
pony2
Post Sun Apr 05, 2009 9:18 pm
zaust wrote:Good plate too. (for astrix fans) As said already. Once it's back in tip top, use it once a week if you can.
That hadn't occurred to me. :)
Zizzle
Post Mon Apr 06, 2009 3:26 am
NICE! :cool:
I wonder how long it will take people to notice this...
love30
Post Mon Apr 06, 2009 10:33 am
lovely M3.
gary
Post Mon Apr 06, 2009 5:25 pm
Nice one mate. Looks really clean and tidy
pony2
Post Mon Apr 06, 2009 7:32 pm
Theo, did you get my pm?
punk_sy
Post Mon Apr 06, 2009 7:40 pm
harry_p
Post Mon Apr 06, 2009 9:00 pm
i changed from 16s to 17s and to be honest, the difference in handling and feel is minimal, as long as you don't go silly with the tyres. the fat arches will easily swallow wide rubber, but going too wide will mess up the feel and balance of the car.
the 15in wheels used 205 55 15 tyres, the stock 16s 225 45 16, and i have one set of 17s with 215 40 17 all round, and one set with 215 45 on the front and 235 40 on the back. i personally prefer the 215 40 17s all round for a nice balanced drive without the sidewall rollover of the smaller wheels. ride is marginally worse on small sharp ridges and lumps but far from uncomfortable. as you ssay, an m3 is fairly firm anyway, and i like my cars to feel nice and direct.
the 215/235 setup looks the best, but can lead to a little more understeer, you just need to adapt to it, go in a touch slower, make use of the extra traction by getting on the power sooner on the way out 8)
car looks great, good luck with it, once you get it to a standard you're happy with, you'll never want to sell it :D
cheers,
harry
pony2
Post Tue Apr 07, 2009 8:13 pm
Thanks Harry, it is really good to get the opinion of someone who has tried both sizes, I will check what size tyres are on there. They are Continental so probably the standard sizes have been used.
