Right, I've had this car for a year now, so I thought I'd better update my thread. Most of the exterior rust was sorted last year, still a bit round the rear arches, and some inside the boot but I will sort that out when the weather cheers up a bit, but in the 12 months I have had the car I have done:
Ӣ Fitted new Halfords extreme brilliance bulbs to the dipped beam
Ӣ Fitted my old Alpine head unit
Ӣ New fuse box cover fitted (Genuine BMW)
Ӣ Aluminium Front Strut Brace fitted (eBay Special)
Ӣ Oil and Filter changed
Ӣ Second hand BBS Cross Spoke alloys fitted with Dunlop SP9000 Tyres
Ӣ New BMW logo's fitted to centre caps (eBay Special)
Ӣ ATF added to engine oil for 100 Miles
Ӣ Parcel Shelf speakers replaced (Pioneer)
Ӣ Crash Repairs
Ӣ Second Oil and filter change
Ӣ Fuel filter changed
Ӣ Air filter changed
Ӣ New Spark plugs
Ӣ 5mm Wheel Spacers fitted to rear wheels
Ӣ New Aero style wiper blades (Bosch)
Ӣ Repairs To Rust on bottom of drivers door
Ӣ Drivers door removed and whole bottom panel sprayed
Ӣ New thermostat housing to radiator bottom coolant hose fitted (genuine BMW)
Ӣ New front ARB Bushes (Powerflex )
Ӣ New front ARB drop Links (eBay Special)
Ӣ Repaired wiring on illuminated gear knob
Ӣ Replaced Steering Rack with another E36 rack (Genuine BMW)
Ӣ Reset SIL
Ӣ Re checked and adjusted valve clearances
Ӣ New Shocks Fitted (Bilstein gas filled OEM)
Ӣ New suspension springs fitted (Apex 30mm Drop)
Ӣ New top mounts fitted all round (GSF)
Ӣ Fit New exhaust rubber on back box
This year I intend to replace all brake pads and rear discs, fit new lollipop bushes, (this weekend weather permitting as the parts are taking up room in the kitchen) fix a blowing exhaust, repaint inside the boot, and fit more new front ARB drop links.
Whatever you do, DO NOT buy ARB drop links off eBay, they have only lasted about 2000 miles on my car, but seeing the quality when they arrived I kept the old ones as they weren't too bad any way. No pictures at the moment I'm afraid as my server connection seems to be playing up, but I'll update tomorrow with some pictures when I can get at them,
Thanks for reading
