My 325i cab started life as a 318 (i think) and had the 2.5 lump put in last year before i bought it, a friend tells me they should of changed the diff also otherwise the gears will be too short when pulling away?
Is this right and also is there a way of telling easily?
glen
Different diffs?
320Touring
if it was originally a 318i it'd probably have had a 4.10 or 4.27 diff fitted
the 325i should have had a 3.64 or 3.71(3?) or 3.91 diff fitted as standard.
Basically the lower the number, the higher the gearing of the diff (ie a 3.64 is "taller" than 4.10)
there are a few ways to tell what diff you have
1-see what rpm your car is pulling at an indicated 80 mph, the shorter the diff, the higher the revs (my 4.10 pulls 4krpm at 80mph, a 325i with 3.64 should be pulling just over 3k rpm)
2-jack the car up and read the tag attached to the diff casing-the last 3 numbers indicate the ratio e.g 4253614373= a 3.73 diff (look out for an S on the casing (means LSD
3-jack up the car and see if you have a 'small case' diff (ie one that is fairly compact-these tend to have less bolts on the casing than large ones) if so it'll be a short diff-4.10/4.27
hope that helps!
hope that helps!
dannosail
Slightly off track but what's the little sensor plug that goes into the back of the diff for?
M3Compact
Speedo.dannosail wrote:Slightly off track but what's the little sensor plug that goes into the back of the diff for?
glenbat
cheers guys, couldnt locate the tag but found 66640 on the casing?
Does this help?
Does this help?
stuartgallafant
i have a 318iS and i wanna LSD for it
whats the best ratio to look out for:
a) acceleration?
b) top-end?
a) acceleration?
b) top-end?
stulane
http://www.jaredsquires.com/ndp/content/view/17/31/1/2/
^ Good guide to diffs at the bottom of this page ^
these 2 don't go i'm afraid for if u want long legs and top speed u will lose acceleration. The easiest diff for u to find is a large case sport 3.91 matestuartgallafant wrote:i have a 318iS and i wanna LSD for it
a) acceleration?
b) top-end?
or if u are lucky a 4.10 LSD but good luck finding one!
tomtomiS
i had th emisfortune of my diff going in december last year and the only one i could get at the time was a 3.64. my car hits 100 mph in 3rd gear and motorway driving isnt quite so drony plus i get roughly an extra 50 miles out of a tank. BUT its not as eager through the gears and thats what iS's are all about IMO so i might be having the old diff rebuilt when some more money falls from the tree outside my house
stuartgallafant
cheerz guys. i'll be looking out for a 3.91 or a 4.10 and i'll let you know how i get on.
where'd you get the seeds for that tree?
tomtomiS
i know of somebody selling a 3.9 lsd for Ԛ£210
