Beemerlad's M52 Chromie
Post Mon Mar 23, 2009 7:33 pm
Here's a pic of the morsels waiting to go on the front. Showing the one strut housing I have given a tidy up and one brake caliper. Obviously the others are getting done too :)
Wheel bearings/ ABS hubs on their way and also new back plates and then it'll all be ready to go back together. Thank god for air tools when it came to getting those 36mm front nuts off with the struts off the car.
Post Mon Mar 23, 2009 7:38 pm
They are far from perfect but an improvement and should look pukka with the new green Weitec springs and matching green ARB. What a tart lol. The underside is gonna look a hell of a lot better than the topside
initial_g
E30 Zone Moderator
E30 Zone Moderator
Post Mon Mar 23, 2009 7:55 pm
looking good will certainly add a touch of anti corrosion too and keep em lookin fress for afew year
Post Wed Mar 25, 2009 5:50 pm
Right, wheel bearings arrived today, picked up the back plates and assorted nuts from the dealers after work, got my rags on and am about to get out in the garage and tidy up the other strut and caliper and put the other one back together.
maybe some pics later
Actually feeling quite positive about this car now, you know what, it may actually be finished very soon :P
Who needs an exhaust system, think i'll run a pair of scaff tubes as a side exit :D
punk_sy
Post Wed Mar 25, 2009 6:15 pm
lol do the scaff tubes :cool: its great when you just get the urge to work on your car then the next day cant be arsed :mad: lol well i keep doing bits then leaving it for days :cry: .
im moving workshop soon tho bit closer to home and better building :P so shud be aat your stage soon !
Post Wed Mar 25, 2009 6:46 pm
lol, people are normally at my stage after a weekend :)
But to be fair, pretty much all of the suspension, bushes etc and brake pipes are brand new and it has had a good tidy up underneath so hopefully no MOT concerns for a while
Bob_S
Post Wed Mar 25, 2009 9:25 pm
come on lee I want to see those wheels back on the floor!!! :D
Bollocks to this 24v scrap!
Post Wed Mar 25, 2009 9:36 pm
Bob_S wrote:come on lee I want to see those wheels back on the floor!!! :D
K'in hell mate, give me a chance :)
Learning as I go here too by the way. Although when you get down to it, it's not rocket science is it.
Well tonight I spent a pleasant few hours in the garage, annoying the hell out the neighbours no doubt with my friend the angle grinder and the compressor and windy gun.
Here's the passenger side strut housing with it's new friend the B6 inverted damper all snug.
Shame it then gets all covered up by the rubber boot
Glad I have air tools as even using the gun it took some time to get the spring compressed enough to get the damper rod through the top plate, these B6 dampers are short.
Spring and top mount all on and new back plate and wheel bearing fitted
Can anyone spot the problem in this shot?
Tarted up caliper and carrier fitted, just mocked up as I found I had run out of threadlock for the mounting bolts. But I know where I'm at with this now and once the paint has dried on the other leg I'll get that one bolted together and then it'll be ready for fitting the new wishbones, eccentric rear polybushes and my god this thing will be sat on 4 wheels again (until I have to molest the rear end to fit the springs and dampers), which don't look like a lot of fun with all the shizzle to remove inside a touring to get to the top mounts.
Dan320is
Post Wed Mar 25, 2009 10:31 pm
E30BeemerLad wrote: Tarted up caliper and carrier fitted, just mocked up as I found I had run out of threadlock for the mounting bolts. But I know where I'm at with this now and once the paint has dried on the other leg I'll get that one bolted together and then it'll be ready for fitting the new wishbones, eccentric rear polybushes and my god this thing will be sat on 4 wheels again (until I have to molest the rear end to fit the springs and dampers), which don't look like a lot of fun with all the shizzle to remove inside a touring to get to the top mounts.
The rears are easy chap, just make sure you have a magnetic pick up tool because it's easy to drop the topmount nuts down into the car. Alternatively, stuff some rags in the large hole so the nuts wont drop down the hole.
Bob_S
Post Wed Mar 25, 2009 10:49 pm
no chances here lee, your taking longer than an epic thing with frostbite!! :P lol
glad to see you making progress.. those rears wont take long at all!!
toby
Post Thu Mar 26, 2009 3:55 pm
E30BeemerLad wrote: Can anyone spot the problem in this shot?
Do you mean this picture?
The hole for the front disc retaining screw doesn't line up?
Post Thu Mar 26, 2009 5:04 pm
Bingo!
Is this really a problem once the wheel is on and tightened up?
Chris-W
Post Thu Mar 26, 2009 5:10 pm
Not a problem at all.
winx
Post Thu Mar 26, 2009 5:12 pm
with the wms kit they don't line up either but is fine once the wheel is on.
If you take wheels off regularly it will be a pain as the disc spins on the hub making lining up bolt holes a pain, even worse if you have to have spacers for the wms kit :-x
**BANNED**
Post Fri Mar 27, 2009 5:45 am
I find that the sodding little retaining screws rust firmly to the disc,I take Mr Angle Grinder to the face of the screw now when the disc is worn out and try to leave a stub for the new disc to sit on. winkeye
Youth is wasted on the young.
Daf318is
Post Sat Mar 28, 2009 9:31 pm
I go away for a week with work and come back to find out you did all this I almost died of shock! Nothing has happened for months and now all this :D Good stuff! Keep up the good work Lee :cool:
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
Post Sat Mar 28, 2009 9:47 pm
Would have built up the other side today butI'm feeling sorry for myself with a cold and didn't fancy a day in a windswept garage.
Took delivery of a much better condition tailgate today and Alpina front valence/ spoiler.
Looking at getting out in the garage tomorrow and getting the other leg built up and then bolt on the new arms and get it back on 4 wheels.
Fitted the car bra to the bonnet :mad:
**BANNED**
Post Sat Mar 28, 2009 10:07 pm
Ahhh,man flu,terrible sickness that woman does not suffer from!Car bra....very gay... I am trying to sort niggles with mine,current puzzle is why do the brakes apply themselves after the car has been running a while? And why does the clutch feel heavy with a cold engine but much lighter with a warm one? Did manage to bottom the cold running,fitted a new 'stat...£44.31 :cry:
Post Sat Mar 28, 2009 10:29 pm
I put a new stat and water pump in mine when I had the headgasket/ Baileys coolant moment last summer.
Now I've paid for them, I'd also like to announce there are a pair of Schrick cams to go in, allegedly these cams on another M50 with a remap were putting down 226 ponies, so I'll be a happy boy if I get that.
I'm also waiting to hear back from a friend who I know is a very capable welder who may be able to sort out the S50 manifold and turn that last primary tube as I would like to use the S50 mani if possible
bodger
Post Sat Mar 28, 2009 10:39 pm
daimlerman wrote:Ahhh,man flu,terrible sickness that woman does not suffer from!Car bra....very gay... I am trying to sort niggles with mine,current puzzle is why do the brakes apply themselves after the car has been running a while? And why does the clutch feel heavy with a cold engine but much lighter with a warm one? Did manage to bottom the cold running,fitted a new 'stat...£44.31 :cry:
might be nothing to do with your problem daimler but i once serviced my mums corsa diesel and mistook the brake reservoir for a power steering reservoir.so topped it up with power steering fluid and as the car warmed up the brakes would gradually apply themselves until the car wouldnt move.....half hour later it would be fine again until they warmed back up :x had to completely bleed the system a few times and change the master cylinder :cry:
obviously not saying you are as thick as me but i was told even slight contamination of the brake fluid can cause this, maybe run some fresh fluid through or could be a knackered master cyl
**BANNED**
Post Sun Mar 29, 2009 11:33 am
Proper thread hijack! Thanks,bodger,I fitted a new brake master because the pedal although firm,was slowly dropping to the floor.It was after this that the brakes started binding.I let a bit of fluid out of the new master yesterday via the unused port on it's bottom(ABS system) so I will see how it goes.
Post Sat Apr 11, 2009 11:47 pm
Well, some progress to report on today. Started decorating the living room with the missus, but soon started cursing & swearing and she kicked me out to work on the car lol. Ain't she a diamond.
Finished bolting up the brakes on the front and got the wheels back on, another milestone. Quite like the stance on the front, only a 40mm drop and not forgetting I'm on 60 profile balloon tyres at the mo.
Can't be arsed to totally clean up the wheel houses, the factory underseal is still very well intact.
Then I thought I would unbolt the M52 manifold in order to have another look at the S50 manifold to see where I would need to butcher the rear primary and have a gander where the steering column is going to spoil the fun.
So I got the S50 out and got the rear branch into position and after some wiggling and cursing I actually got the damn thing on, well this changes everything and so I got the front branch out and then the fun started. Trying to get both manifolds into position is a royal pain in the arse and something I never hope to have to repeat. Process was ARB undone, remove driver side engine arm and jack engine on that side. After colossal fannying around it's on and I'm comfortable with the clearance I have on the steering column.
Need to finish off with the undersealing and general tidying up, but this shows where the pipes come down, not too low.
Hell I may even get this thing finished soon.
Post Sat Apr 11, 2009 11:49 pm
looking good lee almost there :D
E30Gheko
Post Sun Apr 12, 2009 12:17 am
Great work there fella! A real milestone indeed!
Quick question. I'm looking at your poly bushes on the front control arm and wondering how you got them into the lollipops? I'm having a nightmare trying to get mine in! :roll:
Post Sun Apr 12, 2009 12:24 am
I have no idea dude, I'm a lazy chancer and Bob_S did them for me :)
E30Gheko
Post Sun Apr 12, 2009 12:32 am
No worries. I've looked again and I don't think they're the same as mine.
What's next then? winkeye
leeparkes
Post Sun Apr 12, 2009 12:33 am
Ive been watching this thread from the start and with all the problems youve come across lets just say they all in the past,especially the mainfold headache!
Hope you enjoy finishing off this conversion/resto
best of luck!
Post Sun Apr 12, 2009 12:42 am
Thanks guys.
The manifold is a big relief, I wanted to stick with the S50 as I'm sure there are some gains to be had and the ports are certainly larger than the M52 ones. With the schrick cams and remapped ECU I hope to be knocking on the door of 230 ponies.
Next job is fit the x pipe which came with the manifold and then have a look at how I'm gonna get my 2 piece system mated up, obviously a bit of chopping and welding will be required. Then it's time to get the rear end in the air and get the koni dampers and the lowering springs fitted. Then we're onto fluids, fill coolant, fill and bleed brake and clutch systems and fit new front to rear brake pipe and fuel pipes. After that it's pretty much done and time to start worrying about the VIC check and mostly the MOT.
I'm pretty certain on the paint now, matt black, red wheels with whitewalls. Refurbing some cup style alloys at the mo.
Post Sun Apr 12, 2009 1:16 am
Too be fair, the S50 manifold is too big for the M50.. Any gains if any, would be at the top of the rev range due to the huge step from the port size to the manifold primaries.. Mine went ok with it on though, and sounded great!
Bob_S
Post Sun Apr 12, 2009 11:15 am
I'm no tuning god or anything and feel free to correct me but any gains to be had with the enlarged mani will surely be taken away by the rest of the system being a fair size smaller?
G;ad it fits though lee!
Daf318is
Post Sun Apr 12, 2009 1:48 pm
E30Gheko wrote:Great work there fella! A real milestone indeed!
What's the problem Rob, I polybushed mine no problem - give me a call if you want. I just used some wood and a vice! Hell I even put one of mine in the wrong way round and had to get it back out again :o:
keri-WMS
Post Sun Apr 12, 2009 2:16 pm
Jhonno wrote:Too be fair, the S50 manifold is too big for the M50.. Any gains if any, would be at the top of the rev range due to the huge step from the port size to the manifold primaries.. Mine went ok with it on though, and sounded great!
From what I've been told (by flowbench-owning engine builders) it's nice to have a step from a small port to a large manifold, this acts to set up the shockwave that works to "tune" the manifold to scavange exhaust gasses at certain frequencies (ie "revs"). It also works as an anti-reversion lip to discourage exhaust gasses re-entering the port.
As the car has a "nicer exhaust note" that implies that the step IS creating extra resonance (the frequency is defined by the dia and length of the primaries).
**BANNED**
Post Sun Apr 12, 2009 2:22 pm
Good to see that manifold on,far more fun than decorating! You say you never want to do it again,how are you going to fit those cams without taking the head winkeye off?
dazleeds
old skool raver
old skool raver
Post Sun Apr 12, 2009 2:26 pm
nice one ll
glad to see its moved on mate
am thinking i should find a shell and do a similar conversion sometime in the near future
soon as i get rid of the japcrap that is :x
www.oldskoolfantasy.co.uk
Post Sun Apr 12, 2009 2:27 pm
Can be fitted in situ, just about!
