Ive picked up a healthy 89 535i sport,insurance write off! (light scrape down the drivers side)
here's the spec:
manual
sterling silver
130k with history (recenty serviced)
air con (the fan will be used on the swap)
m-tech kit
m-tech steering wheel
m-tech suspension
black sports leather with rear blind and rear door blinds
LSD
K&N panel filter
green stuff pads
sachs clutch fitted 12 months ago
I paid £200 for the car
oh and £50 for the wheels off 'danthe' to get it on the trailer,
Here's the Pictures of it!
Rear door blinds
and one of the lump!
here's a sly pic of the E30 the M30 is going into
And yes the slipper locks up fine
I will be making notes all the way to the end of the conversion including the total cost,so far it owes me £250,i will break the car so that will bring some of the money back
Let the fragfest begin!
Today was 'engine out day'!
started at 8am this morning and i was cleared up by 2pm,minus a trip to the cafe and i forgot my breaker bar so had to pop home,so you could say it took me 5 hours to get the engine out onto the floor.
The only pain in the arse i came across was a gearstick lock thingy,not sure if it was factory fitted but it was welded to the gear selector rod and came out of the transmission tunnel about 3 inch's on the passenger side,i knew it would stop the engine being pulled out smoothly so it had to come off,i had to cut the metal around the gear stick on the top of the tunnel to get the angle grinder in there and wasted about an hour of scratching my head thinking the best way to tackle it!
Here's the offending item
after this ordeal it was plain sailing and everything went according to plan.
Job done.
The engine ill be removing from the E30 is a high compression M20/b25 with rebuilt head,new sachs clutch 6months (3K) ago along with new water pump,cam belt,etc...,it will be for sale soon and will be sold as a complete conversion.
Thats it for now but just before the m20 gets pulled out i will put the car on a weigh bridge to see its weight then put it on the same bridge when the M30 is in the to see how much weight the car gains,also in going to measure how much the front suspension drops with the big six in there because we all know these big lumps of pig iron are heavy.
Ill keep it updated as i go along with plenty more pics (and problems)
