Might be a silly question...
Just bought a 325i and its a little tappy up top, a friend whos a mechanic says they can just be adjusted and its not a big job, is this correct?
What parts will i need, i guess rocker cover gasket anything else?
Glen
E30 325i tappets - are they adjustable?
SCOTT325SE
if you really want to do it properly, you will need a rocker cover gasket(buy it from GSF) 12 rocker eccentrics (Buy them from GSF for about Ԛ£2 each aswell)it shouldnt need anything else, but if you are doing that, id do an oil change, and give the engine a once-over, so u know that theres nothing else is making a noise.
HTH
HTH
Demlotcrew
They are designed to make that noise. The 325iM20 has no tappets in the sense of the word, but it does have rockers which you can adjust the clearances on!
A
A
SCOTT325SE
sorry, i forgot to say.....
no, its not a big job. Budget 2 hours if you are a home mechanic. A pro should do it in about an hour and 20 minutes, max.
SCOTT325SE
I think we both knew what he meant tho.Demlotcrew wrote: no tappets in the sense of the word, but it does have rockers A
Simon
SCOTT325SE
thats the one!
offtopic - simon, thanks for the light cluster, its now keeping my boot nice and try. ta mate!
Simon
Good stuffSCOTT325SE wrote:thats the one!
glenbat
cheers guys, think im gonna buy basic service parts while im there, is my engine an M20?
SCOTT325SE
320, 323, 325 and 327 engines are all M20 mate.
SCOTT325SE
edit - unless its a 320iS... in which case, its a 4pot s14 engine (baby m3)
glenbat
scott325se
What size rims are on that grey bmw in your sig pic? they look huuuge!!
