VIBE SEK 50 opinions
Anyone own a set of these? How good are they?
I've got a set installed in my cabby, very good
i should be getting a set soon, seems like you get very good bang for buck with em
Excellent. Some cheap refurb ones going through ebay at the moment.
You won't be dissapointed, will sound better if you amp them
I just bought one. Are they better then SEK 50's?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0370515921
They look ok, 100W RMS is good power
What car are you putting these in?
316i 4 door. They seem to be quite a bit more expensive then the SEK 50's.ImysE30 wrote:They look ok, 100W RMS is good power![]()
I've not heard them personally so can't really say. Vibe is very good anyway regardless of modelBlitz wrote:316i 4 door. They seem to be quite a bit more expensive then the SEK 50's.ImysE30 wrote:They look ok, 100W RMS is good power![]()
i just baught a set of these last night
http://www.alphacaraudio.co.uk/ViewProd ... AT_CODE=67
has the same blueprint as a sub so might be quite punchy for a 5" speaker
Can't go wrong with Vibe IMO
never bought any before so dont know what to expect, i hope they are as good as everyone says
rms power of vibe speakers seems really good for the money
Well done Alexnever bought any before
I've always rated vibe, just got aceraf on here, his Vibe system was crazy
i made sure it was spelt wrong just for youImysE30 wrote:Well done Alexnever bought any before:p
I've always rated vibe, just got aceraf on here, his Vibe system was crazy![]()
Are you going to amp them?
if the RMS power is 100w it would be daft not to put something like this in
http://www.alphacaraudio.co.uk/ViewProd ... BCAT_CODE=
buy two sets blitz and amp em
I got one of those in my shed somewhere and a Rockford Fosgate one
its better than my amp and i paid £80 quid for mineImysE30 wrote:I got one of those in my shed somewhere and a Rockford Fosgate one
although ive never heard of splx ???? are they any good seems a worth while upgrade for an extra 25w rms
I paid £100 for my Vibe monoblockAlex wrote:its better than my amp and i paid £80 quid for mineImysE30 wrote:I got one of those in my shed somewhere and a Rockford Fosgate one
I've heard that there shyte
Prices are good on that website.Alex wrote:if the RMS power is 100w it would be daft not to put something like this in
got them today top class service
ive tried them connected to my stereo/computer and the qulity is superb, they have an inline corssove for the tweeter too
they produce good bass for a 5.25 speaker too
Were they amped when tested?Alex wrote:got them today top class service
i tested them through my hifi that i have connected to my computer and that produces 70W rms, so its more powerful than my amp
Hi I just got the speakers and the wire's connectors are different. Would this mean I would have adapt these wire to the cars audio wiring loom?
miniblob
Nip to halfords or somewhere and get (or borrow) a crimping tool and some female spade connectors (check the size or buy a selection!!).
You just wanna crimp the female ends to you're new stuff and plug 'em in!!!
Makes them easier to remove and is better than just cutting and twisting the cables round, which will fall off!!!!!!
327 Touring with bass!!!
So something like this. And would have to crimp the connector on to the new cable and and then they will fit the existing car speaker cable?
http://www.halfords.com/webapp/wcs/stor ... yId_165572
the wireing that is allready in the car should connect straight to the speaker and you can do away with the wire they have given you
On the speaker I can only see a connection where you have to screw the wire in.Alex wrote:the wireing that is allready in the car should connect straight to the speaker and you can do away with the wire they have given you
....By the way the speaker looks very well put together.
ah rite there different to most speakers, in that case if it were me i would just cut the connectors of the wires that are currently there, and remove some of the sleeving so that there is bare wire showing and clamp them in the speaker terminals
So I would use the cars wire's to go directly to the speaker?Alex wrote:ah rite there different to most speakers, in that case if it were me i would just cut the connectors of the wires that are currently there, and remove some of the sleeving so that there is bare wire showing and clamp them in the speaker terminals
yep, no need to add extra wire
Thanks. It has crossovers as well.Alex wrote:yep, no need to add extra wire
in that case you will need the wire then, didnt know it had inline crossoversBlitz wrote:Thanks. It has crossovers as well.Alex wrote:yep, no need to add extra wire
