Does anyone know if the Monitor screen's for the E38 7 series are E38 specific, Or are they interchange able with the E39 or maybe other models.
Im after the larger monitor as I have sound but no vision.
Cheers Sean
E38 bmw monitor screen
Not sure if the 4:3 ones are but i think the 16:9 monitor is. If you go for a monitor I recommend you to go for a 16:9 which is far better then the 4:3. Also you will need a loom for the monitor and I'm sure you also need a video module.
What are you going to use the monitor for?
seanboy
It already has as monitor (larger one) I only get audio and no sound. Thinking of getting one on the ebay. It could be something simple I suppose but how much to find the problem and replace. Thinking would be easier to replace the whole unit?
Oh sorry. I'm not sure what the problem will be.
seanboy
stuartgallafant
I wouldnt just assume its the monitor itself. If you have sound but no visual, its an expensive guess to go for a monitor unit dtraight away.
I would get the video module checked. If this isnt working then that'll be your problem. You're only in Beckenham which isnt too far from me. I could take a look if you want?
