I have a running issue with my car and I'm trying to eliminate parts before I waste any more cash!
Thanks,
Martin.
Now you say that, I didn't have the problem first thing this morning or until a few miles after leaving work!FlappySocks wrote:When I had a bad M50 TPS, the problem only occurred when the engine warmed up, and was most noticeable when accelerating around roundabouts.
im sure i mentioned in another thread that the problem could be inside !.. poss a coil driver? i take it you didnt open up the m/s ?DRIFTBOY wrote:Cheers carannc, trigger wheel / pulley are fine.
Well I've been outside in the glorious sunshine today for some more tinkering.
I've not yet got the laptop thing sorted but...
... I put the M50 TPS back on, changed the CPS and it started!
However, I believe this was purely coincedence, as it soon stopped again.
Then it started again, and I noticed that when it was idling that if I tapped the TPS just lightly (not whacking it!) the engine almost stalled.
So I re-wired in the RS Electronics TPS and it passed my highly scientific 'tap test'!
So, I ran the car round the block and....
... it stopped again!
When I got it back home again I noticed something else, if I gently tapped the MS unit with a finger whilst it was idling the engine almost cut out again.
So, could it be that I had a faulty TPS AND a bad connection in the MS..?
I'm going to have a play with the laptop now!
DRIFTBOY wrote:
Anyone want to buy a whole heap of trouble?![]()
winx wrote:Nope!
