bit of a engine overhaul for the tourer
pete1247
well started today got lots of new parts for the engine along with a sckrick cam gonna replace all the gaskets ,cambelt +tensioners ,leads,plugs,dizzy,rotor arm, and gonna be a little head work to should bring her back up to spec i think
Good luck with it
cliffybabe
- Powered by Nelly
where did u get the cam from?? whats the spec of it how much did u pay??
Lovely touring
I've seen those wheels on ebay i think, what are they called?
pete1247
yea got the cam from ca automotive the spec is 284/272/110
pete1247
done a little more on her today also found out some manifolds should give it a little more power hopefully heres some pictures
pete1247
the stat housing hadnt been off in years took some freeing off in the end
bodger
nice mani, what is it frompete1247 wrote:
pete1247
i brought them a while back they are the cheaper left hand drive version so the back one has had to be modified to miss the steering knuckle paid about £130 for them both with downpipes
bodger
m20 lhd? is that how they come, always assumed the lhd m20's would just use the normal log manifoldpete1247 wrote:i brought them a while back they are the cheaper left hand drive version so the back one has had to be modified to miss the steering knuckle paid about £130 for them both with downpipes
pete1247
yea they are aftermarket manifolds but for a left hand drive
pete1247
also got some sweet badges thanks to ca automotive
pete1247
hi folks just thought id show how the progress is going the heads all ready to go back on hopfully get some more done tommorow but heres how she looks
paulmitchell1984
this looks sweet, id love to do something similar to mine
have you aa link to ca automotive at all?
pete1247
a good friend i know is friends with the guy who own it roy
paulmitchell1984
that head looks similar to the one im awaiting on along with manifold
bodger
nice work, same thing i did to mine just after i bought it, you going to paint the block too
pete1247
does anybody know if pink injectors from a 328 24v are better than the standard 325 m20 injectors
M20 injectors are fine they flow enough for high powered 2.7's
has that head had some work done to the chambers? looks it!
[/img]
