Spraying Taillights
Rickz
Instead of the orange on the standard tail lights, to spray it red, is this the correct method or have any of you zoners got any other ways of doing it?
http://forums.generationdub.com/showthread.php?t=20691
thanks
thanks
iDreamBeemer
masking up is better so you don't get paint everywhere else. Tape it up then give it light coats, letting it dry in between until you hit a good blend.
Rickz
Ah right, so would i have to use the paper or not?
eko
- Old timer
Get yourself down to your local model/RC car shop and buy a tin of Tamiya Transparent Red as in this pic.
Only costs about £3 for a tin as opposed to £10+ for the Halfords crap.
Finish is much better
maxfield
I paid £3.99 for some Tamiya paint great stuff
eko
- Old timer
What happened to the fishnets then Maxmaxfield wrote:I paid £3.99 for some Tamiya paint great stuff
chisel
Spot on guys. Is it worth using the sand paper to ruff it up first????
maxfield
They went in with the scrapper.
Yes I'd use 240 grit wet and dry to get a good key.
oakey
^ The light will have visible sanding marks all over it
Ziggy
240 is way too rough - use something like 1200. & don't try and do it outside / in a (cold) garage unless we get a warm day!
maxfield
I used 240 and came out great. Also used laquer though.
E30_Jatt
Hi, this seems quite easy enough to do but I was wondering if anyone knows if it is ok to spray the reverse light as in its not an MOT fail and its not illegal.
Sanchez
only MOT fail that I know of is the reflector must reflect light and bulbs showing through the right colour.
ie white reverse light and amber indicators.
E30_Jatt
so as far as tinting the lights go if i were to tint the indicator lenses red it would be a MOT fail? as it would give out red light instead of amber is this correct?Sanchez wrote:only MOT fail that I know of is the reflector must reflect light and bulbs showing through the right colour.
oakey
IMO the lights look best with the reverse light left white.
Sanchez
depends how red you do it.
do it on a spare pair of lenses and put the originals on for the MOT.
E30_Jatt
yea that seems like the best thing to do. Now I just have to get hold of some spare lensesSanchez wrote:depends how red you do it.
konfuzion
I just used warm, soapy water, masked up everything but the indicator area then a few light coats of tint (which I got from Lloyds Motor Spares).. came out just fine IMO:chisel wrote:Spot on guys. Is it worth using the sand paper to ruff it up first????
These have been done for ~6 months now.
Been in front of ol' bill a fair few times and none have battered an eyelid at the fact they're now more of a reddish orange than bright orange. MOT time may be different, I'll see what they say and have a spare pair in the back just incase.
Regards,
Ian
Kingdoms are run by Kings, Dictatorships are run by Dictators, England must be a Country.
Zizzle
Id get a bodyshop to do them, there is a really good way of doing it! for the best non faded results!
I could recommend a place too!
I wonder how long it will take people to notice this...
panesar_e30
any pics of what they would look like from a b.shop? i normaly spray them with the folia tek stuff but have seen a few cars around where the rear lights shiney / laquer effect.
Zizzle
I can get you picures of range rovers/mer ml ones we doo??
chisel
Be carful to get the right colour, I got some the other day and it was more of a red orange and look pants lol. A bit of thinners took it straight off though. Get the colour right and you should get away with it.
panesar_e30
any pics?
tari
I think if you lacquer the lights after, they come out shiny?? I might give this a go.
konfuzion
Spray them well enough and there's no need to lacquer, IMO.tari wrote:I think if you lacquer the lights after, they come out shiny?? I might give this a go.
The ones in my previous pic have never been lacquered. Lights were wiped over with meths, sprayed with 2 coats and refitted.. doesn't get much more simple
Regards,
Ian
