i am considering buying an mtech 2 body kit for my 4 door saloon. problem is mine calypso red, the kits white or black. need to get it resprayed. will i need to get the paint code and have it match, or will i find the colour without having to match codes?
also, with regards to pins and fittings, anyone know whats required for a 316i 4 door
respray body kit
Best to match codes.
You will need a full fitting kit (if the seller doesn't include it). The kit costs about £50 from the main dealer (OEM Parts section one here).
moh110
ah ok, as long as i can get it all in one package so to speak. would be hassle to get each part individually from different places.
how much do u think is reasonable for the kit? its in VG condition.
Is it genuine and not fibreglass?
moh110
im not 100% sure. ill double check with the seller. hes asking for 450
If it's fibreglass, walk away.
If it's genuine and in VGC then worth around £400 mark
- E30 Zone Meets/Events Team
As above, fibreglass walk away for that price, should be origional
moh110
ok i will double check. just awaiting a reply. i think im gonna hang on to mine now, 325 engine and m tech body kit will do the job :p the only i worry about is with the car being low as it it, and the body kit, wont it limit the way i can throw it around? i wana make use of the 325 engine, but i fear ill have to slow down to go over a man hole cover every 2 seconds
How much is the car lowered by?
moh110
im not sure exactly, but as it stands i need to take great care over bumps
Sound's to me like you have a 60mm drop.
With fitting the 325 engine you will also need to run the 325 suspension set-up. 40mm drop is ok
mrLEE30
your paint code will be on the inner wing, next to where it says calipso red there will be a three didgit code followed by a batch code i.e. 709/1234. the 709 is the paint code, take this code to any paint suppliers and tell them its from BMW , code 709 (or what ever your is) they will be able to match the paint.
As for your kit fitting it is covered in the wiki pages..
http://www.e30zone.net/e30zonewiki/inde ... ar_bumpers
