Idle speed problem, and door rubbings!
bmwe30mtech
Post Sun Jul 24, 2005 10:03 pm
Hi, My car is a 318 i and idles very slowly, so keeps stooling, which is very annoying! :( Can any body tell me how i can put the idle speed up, and what it should be set to?
Also does anybody know how to remove the rubber door strips on the sides of the car?!
Many thanks in adavnce to any help, :cool:
Paul
johnono
Post Sun Jul 24, 2005 10:10 pm
door seals should just peel off, give em a good tug and they should leave the car in one peice :roll:
as for the idle, im not to sure, but has it had a service recently?
Martinaston
Post Sun Jul 24, 2005 11:04 pm
The car keeps stooling :?
What shi*ting itself :lol:
The door trim has a plastic nut thats visible when the doors open, below the lock. Take it off and pull the strip away from the car until the stud is out the hole and slide the trim forward (or back can't remember) about an inch and it should just drop off.
As for the slow idle have you had a look at the air filter ?
320Touring
Post Mon Jul 25, 2005 4:39 pm
your idle problem could be caused by a dirty Air Flow Meter (AFM).
try disconnecting the lead from it and see if the idle levels out.
if it does, you can try cleaning the AFM using some carb cleaner.
failing that it could also be the Idle Control Valve (ICV)-this can be disconected and cleaned too (careful tho :wink: its Ԛ£50+ for a new one!)
one other option could also be an air leak somewhere in the air intake piping, so check that carefully.
Hope this helps
see pic below for locations of the ICV and AFM on the m40 1.8i
bmwe30mtech
Post Mon Jul 25, 2005 5:54 pm
Thanks guys. :cool: The car is almost ready for a service. I was expecting there would be a screw to turn or something for the idle! I will have a look at the air filter etc, and thanks for the picture, that should help me! :D
Paul
bmwe30mtech
Post Tue Jul 26, 2005 6:42 pm
Hi guys,
Got the strips off the doors, but cant get the plastic clips out! Are they just push in clips, or are there nuts on the inside im batteling against!? Given them a good yank, but dont want to break them.
Thanks very much again, :D
Paul
bmwe30mtech
Post Tue Jul 26, 2005 7:21 pm
I left that post too soon, just got the plastic clips out. I am fitting a m tech 2 kit, and the m tech kit clips dont fit properly into the holes left by the clips that held on the door rubbings, the holes are too big. Am i missing something??!! 8O
Paul
