Leccy fan size..
I reckon that would work fine Johnno.
I'm using a 14" Spal on the M30 turbo and it does a great job, with E28 535i radiator.
ian332isport
- Contact:
Dan,
14" is the biggest you can fit on the M3 radiator. I initially used a 14" Pacet Profan, but replaced this with a regular E30 aircon fan (also 14") when I fitted the aircon.
Ian.
Ian.
jaistanley
I'm now looking for one for mine (who thinks I can get this car on the road in two weeks of graft and spending???).
Does anyone have any wiring diagrams and part numbers for making my own 2 speed fan controller that will work with a pacet 14" fan??
Cheers guys.
Jai
Cheers guys.
Jai
Alpina B6's used this setupwinx wrote:e34 aircon fan infront of the rad, as soon as it kicks in seems to do a very good job!
I've got an E30 M3 electric fan taking up space if anyone wants one
RoadHazard
Is the E34 fan a direct fit? Or do I need some custom job to make it fit?
Right now I have the 5-blade E30 air con fan. Will this be adequate?
I think Ian332i is running the E30 air-con fan, so it should be up to the job - Ian doesnt cut corners or accept poor substitutesRoadHazard wrote: Right now I have the 5-blade E30 air con fan. Will this be adequate?
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
ian332isport
- Contact:
Yeah, I'm running a bog standard E30 A/C fan as my only cooling fan. It was actually from an M3, but I don't believe there's any difference.jmc330i wrote:I think Ian332i is running the E30 air-con fan, so it should be up to the job - Ian doesnt cut corners or accept poor substitutesRoadHazard wrote: Right now I have the 5-blade E30 air con fan. Will this be adequate?
I think it's also worth using the temperature switch from the E36 318 compact, as it switches on sooner.
Cheers,
Ian.
I used a M3 electric fan on mine with the M52 rad from the E36 and it did a sterling job for the month I had it on the road
RoadHazard
Thanks Ian. That's good to know.ian332isport wrote: Yeah, I'm running a bog standard E30 A/C fan as my only cooling fan. It was actually from an M3, but I don't believe there's any difference.
Cheers,
Ian.
Went out to buy a temp switch from E36 318 today. I need anything that could help because I'm in a hot climate. I'm thinking about running no antifreeze like some folks in US because it never gets below 10 degree C where I live but I'm not sure if it's a good idea.
If the E34 air con fan is worth getting, I'll try to find one too.
ian332isport
- Contact:
I really wouldn't advise it. Antifreeze obviously stops the coolant from freezing, but more importantly, it has corrosion inhibitors.RoadHazard wrote:I'm thinking about running no antifreeze like some folks in US because it never gets below 10 degree C where I live but I'm not sure if it's a good idea.
Without these, your engine will slowly digest itself from the inside and the cooling system will silt up and make matters worse.
Ian.
RoadHazard
Alright. Got some antifreeze from BMW ready to be mixed and poured in. Just need to hook up a hose from the engine to the expansion tank. Can't source a good hose that has the right bends yet.
I'm going to use the 5-blade AC fan for now. Do I have to modify the fan circuit or I can leave it the way it came from the factory?
