evening all, HELP!!
i have not been on here for a while but some of you may remember a while back i wanted to do an e30 convertion to 4x4.. well the plan changed as i couldnt find a good e30 for the money i was looking to spend.. anyway... current plan goes as follows..
i have bought an E30 325 convertable (automatic) and i plan to put the engine from my old E36 328 (manual ) into it.
Questions:
1- i seem to remember on here there was a PDF of the haynes or bently manual for the 328 engine (i need to strip and rebuild to insure no problems with the engine first) but cant find the link anymore, can you help??
2- my plan is to put the manual e36 gearbox in the car to save issues with mating engine to gearbox, is this a good idea? also to save ECU issues as the automatic has a second ecu for gearbox i believe.
3- would i be right in thinking the main parts i will need to source are; E34 sump and pick up, new steering column, and E36 engine mounts?
any other advice will be greatly receieved, and i will get some photos up on here when i can find them all, in the mean time if you want to see the collection of BMWs i have or have had and the parts i am using look at my bebo (link below)
http://www.bebo.com/cooots
PS. any old skool mini fans may want to check out my wifes bebo for her recently purchased mini 30
e30 328 CONVERTABLE *PICS NOW INCUDED*
cooots
cooots
some photos of the convertable
followed by the doner car before and afters
the lump
and my current E46 M3 (love this car but tis for sale unfortunatly)
the lump
I remember the E30, was for sale late last year IIRC, different, looks nice.
cooots
yeah bit of a story with that too, i met the guy selling it randomly in a petrol station and at the time i didnt have the money to buy it, it was about a year later almost i happened accross the girl that had bought it on bebo, asked her how much she would want for it and the deal was done......
different yes..... dakar yellow e30 vert........... i bought it knowing it needs some body work as someone has tried to spray the kit while its on the car but, bought it all the same
Fibreglass kit IIRC, will look good with the M52
gcs325i
Looks good mate, where abouts in the country are you? Looks like one that was cutting about this area (Dundee) a year or two ago.
Parts for sale - http://www.e30zone.net/modules.php?name ... 45#2733745
leeparkes
If your doing a rebuild,rebuild it into a M50 iron block
main parts you need to do the swap is an E34 sump/pick up/dipstick,golf or clio brake servo,use the E36 engine arms and the EWS system out of the E36,
not sure what you mean by steering column,if you mean the universal joint mod to do away with butchering the manifold well it has been done but i think the manifold still needs a touch of 'adjustment' (could be wrong)
Gearbox: there is a few boxes that can be used also if you can get an m20 flywheel (its lighter)
Good luck!
Good luck!
cooots
gcs325i- im in aberdeen, and your right the car was in dundee previous.
leeparks - thanks for that, sounds pretty straight forward
Sanchez
BadDave is in Aberdeencooots wrote:gcs325i- im in aberdeen, and your right the car was in dundee previous.
He is good with engine bits and pieces.
e30_singh
are you a rich farmer?
