M30 / E30 custom loom?
Driftben
i currently have a M30B35 with no loom or gearbox which im sticking into my E30, i was thinking of fabricating a new engine loom. what is your guys thoughts on this?
im also looking into after market ECU. any preferences on this?
cheers
ben
cheers
ben
DRIFTBOY
Fabricating an engine loom sounds rather complicated to me!
I'd just get a loom from a scrappy, I bought on a while a go for about £30.
Megasquirt is a popular choice (and the one I'm using) of ecu on here and a few guys are well clued up on it, but not me!
Seems to be cheaper than the others..?
I've never had another after market ecu so I have nothing to compare it to.
Driftben
ah i see. how easy is it to mod the E30 loom to work with the M30?
this megasquirt, where can i get it mapped? and how good is it on forced induction?
cheers
cheers
DRIFTBOY
It depends which E30 you are starting with but my facelift 1988 325 I c101 plugged straight into the M30 loom.
Only two wires had to be swapped over (for the swingyometer thingy under the rev counter) and one wire cut and run down to the starter motor.
Ant (A-Tech) on here is a Megasquirt whizz, he mapped my M30 turbo for me, so that answers that too!
I have a complete Megasquirt ECU from my 325i Sport available - please PM if interested
Driftben
mines a 89 320i so might be slightly different? hopefully not though.
is there any mods i need to do to the loom while the engine is out?
ill pm Ant once im sure on whats going on with the loom situation. good news about the forced induction route though. supercharging is my route hopefully.
so much to do so little time
DRIFTBOY
I don't think it'll be different.STiBen wrote:mines a 89 320i so might be slightly different?
If the M30 loom is the same as mine was (1988 535i) then swap the black & white wire on pin 3 with the black & purple on pin 8.STiBen wrote:is there any mods i need to do to the loom while the engine is out?
Then from the body loom run the black & green from pin 15 to the small spade connector on the starter motor (or you'll have no heater, electric mirrors, sunroof or windows (unless the door is open).
Ant is well into supercharging too, so no worries there.STiBen wrote:ill pm Ant once im sure on whats going on with the loom situation. good news about the forced induction route though. supercharging is my route hopefully.
He's usually a busy guy though so you might need to plan ahead to when he can do it.
Driftben
Well that's the thing I haven't got a m30 loom, only a e30 so is there anyway I could mod that to the m30 engine?
Wondering if it's easier to fab. And fit the charger when the engine is in or before it's in?
e30_singh
Theres a M30 loom for sale on the bay at the moment...
Driftben
Which loom was you looking at? There's 2 and one says it had a rare electronic throttle?
DRIFTBOY
From what I can make out the electronic throttle can be done but is best avoided by most people!
Also, I have heard of people modify the M20 loom, but I don't know what that involves myself.
Driftben
Hmmm I was sure too that someone had modded the m20 loom to the m30 lump. Can't find out who though. Don't fancy going down the route of the electronic throttle because of the charger and to try and keep it simple.
Just wondering. While I have the engine out is there anything I need to do to the bay? Will probably swap the rack for a z3 unit and move then move the battery but other than that is there any more things to get on with?
Ben
Ben
DRIFTBOY
Yeah, beat the bulkhead behind where the cylinder head will be in with a club hammer!
Find either an E30 M3 or E36 328i manual propshaft, or it's a custom E34 / E30 hybrid jobbie.
Rack changes are a lot easier with the engine out so that is the ideal time to do it.
Driftben
Ah great input. I'll get on and do that, I'm good with a hammer and beating things.
Need to get my hands on a z3 rack now.
The search goes on.
The search goes on.
- E30 Zone Meets/Events Team
That's what i've done with my prop all for £100 , cut and shut, and balanced tooor it's a custom E34 / E30 hybrid jobbie.
DRIFTBOY
I did mine in the vice in my garage, lined it up by eye and welded it up!
I do not recommend that method though, I think I was very lucky to get away with it!
And for the last few months it's put up with somewhere around 300bhp too!
Lucky indeed
DRIFTBOY
Yes, but I have an E30 M3 prop which I'm going to fit soon, I don't trust the Scrapheap Challenge welding enough to leave it on there!
It's lasted for about two years and 16k miles without the turbo mind you!
How easy is the turbo conversion????and any pics??
DRIFTBOY
Not easy!
To save spamming this thread, here are the pair of links that tell the tale (big threads though!).
But basically, I cheated!
Toby Unna (well known on here and from PPC Magazine) did the difficult stuff and then sold it to me.
http://www.e30zone.net/modules.php?name ... =m30+turbo
http://www.e30zone.net/modules.php?name ... &start=550
Driftben
where did you get that done from?Rav335uk wrote:That's what i've done with my prop all for £100 , cut and shut, and balanced tooor it's a custom E34 / E30 hybrid jobbie.
ill be lookin into doing the prop soonish. £100 isnt too bad but cheaper the better.
or theres free from scrap heap challenge driftboy haha.
Driftben
why thankyou for that.
the search is over before its started
cheers
ben
cheers
ben
