Hello everybody, I’m tuning eproms here in France for most of the E30 chassis (318is/320i/325i/M3E30”¦). I could make any specific calibration according engine modifications (camshaft, air intake, exhaust, 2.7 modification”¦).
To show you what I can manage , I did a turbo conversion on my car using modified calibration on the OEM ECU (325iph2 ECU 0261200173), several 327i, race engines, 3.5 swap engines and so on.
Moreover, I’ve got most of the original Tuner files from Hartge/Alpina/AC Schnitzer. I can certify the authenticity of the files as we baught the ECUs! So if you manage to refurbish an Alpina or a Hartge car, I could help you on the ECU side.
So if you’re interested in any eprom modification at your specifications (engine modifications, specific fuel, rev limiter”¦), feel free to contact me.
Eprom tuning at your specifications
Hi, so you can basicly reprogam Bosch motronic ECU's to anyones spec?
You say you have original tuner files?
Do you have an Alpina C2.5 spec file?
