cosworth conversion
markybumpit
Sat Jul 23, 2005 5:21 pm
im after doing a cossie conversion into my 87 325i sport but need help on where to get the engine mounts prop shaft and instructions on how its done... i know people have done it before but cant find anything.
any help would be helpful
thanks
Jon_Bmw
Dangerous when thinking
Sat Jul 23, 2005 7:12 pm
Why convert a 6 pot rightness into a 4 pot wrongness!
Personally i would sell the sport for 3-5 grand, with that buy a 325 with a blown head and start there. Or better off leave the ford engine in a ford, or put it into a mk2 escort, that i would agree with.
Whatever floats your boat though, your car your money.
markybumpit
Sat Jul 23, 2005 11:14 pm
love the e30 shape, dont like the engine too much, would prefer a turbo. always wanted a cossie but dont like sierra's, and want rear wheel drive.
Rearwheel_nick
Sun Jul 24, 2005 12:14 am
see people keep harping about 6pot wrongness, but with a 4pot up front the handling is miles better. i think dropping a YB in would be really cool, its been done on e36's before with success :cool:
markybumpit
Sun Jul 24, 2005 1:03 am
thanks mate just tryin to find someone whos done one and peck there heads for info.. haha. whats yb stand for ?
Rearwheel_nick
Sun Jul 24, 2005 2:10 am
YB is just the engine code, theres different variant of it YBT, YBB, YBG etc.
if you want big power, find an engine from a 4x4, (got the 200block, thick wall casting)
i havent done a cossie conversion and i dont know of one in an e30, but you cant go far wrong from just taking an engine out of an e30 and having a look at how its going to sit, size isnt an issue E30's can accomodate all sorts of engines. only thing i can think is height i havent a clue about how tall a Yb is.
think of it this way, get a cossie engine(yb) get the borwarner t5 box. and cram the bastards in. you gotta work out about mounting the engine, youl need a prop made up to go from back of T5 box to the e30 diff.
once its fitted (sounds easy saying it i have no idea what issues youll come across) you just have to wire it up. use the cosworth usual stuff. pectel. probably the simplest.
hope thats of some help. i mean its vague as i have no idea about fitting a yb to a e30 but you should definately go for it :cool:
markybumpit
Sun Jul 24, 2005 12:10 pm
definatly going to have a go, never done anything like this before thats why im posting help. is the borgwarner box a cossie one ? whats the differences ? and how hard would it be to wire one up ? pectel ? is that a standard or aftermarket ecu ? thanks again
Rearwheel_nick
Sun Jul 24, 2005 2:53 pm
borwarner T5 is the box rwd cossies came with, its a strong bastard.
pectel as far as i know is the management cossies came with, pectel is an aftermarket ecu maker but cosworths came with it from the factory. although i have a feeling some might have come with magnetti marelli.
really wish i could help with wiring the engine up, but like i said i have no idea about this conversion and wiring is a pet hate of mine anyway :cry:
you'll most likely need to fabricate up some mounts to attach the engine, i have no ideas about how the engine will sit on a e30 crossmember and if there is any issues with sump clearance or anything.
you'll also need an exhaust made up, hopefully the standard exhaust manifold won't fowl anything in the e30 engine bay.
trying to think of any other things that migh be a problem.
basically get an e30 take everythin out the engine bay, get a cosworth Yb and size the 2 up and lower the engine and box in and see how they are going to need joining together.
using the borgwarner T5 you will need to sort out gearbox mounts to.
not a clue about size differences between the borgwarner and the getrag box the e30's came with not sure if he transmission tunnel will accomodate the borgwarner, and you might need to cut the tunnel about a bit depending on placement of gearlever.
it can be done though, but like any engine swap from a different manufacturer certain things will need to be made. i think its a great idea personally though, :cool:
markybumpit
Sun Jul 24, 2005 7:58 pm
well just managed to get hold of some mounts and a modifyed crossmember for use with the yb engine into an e30, yey. just need to get an engine, box and others now... oh and maybe a donor 325isport with blown engine or summat. cheers for the help though.
Sjoerd320i
Sun Jul 24, 2005 8:02 pm
no sport mate!
just get a 325i with mtech kit or summit :wink:
markybumpit
Sun Jul 24, 2005 9:15 pm
why not a sport mate ? whats the differences ?
markybumpit
Sun Jul 24, 2005 9:21 pm
also what about a convertible ? is there much difference in weight? i wanna make mine quicker than a sapphire cossie.
Rearwheel_nick
Sun Jul 24, 2005 11:04 pm
just get any old e30, just get one with a decent shell and thats cheap, since your changing out the powerplant anyway,
sure it can be made faster than a sapphire cosworth. they are both rwd machines and youl both have cossie power.. however if you mean a 4wd sapphire then that might be more difficult since they have obviously way more traction off the line and be able to corner faster.
where did you get the modified crossmember and mounts from?
markybumpit
Mon Jul 25, 2005 12:51 am
got them off a guy from here, cant remember his name but hey if they work buzzin. am lookin at a 318 will that do ? what about a cab ? are they wey heavy ?
Jon_Bmw
Mon Jul 25, 2005 11:17 am
Personally i think the 318 might not be the right choice, yes you can get them for dirt cheap, but it won't have bigger discs, better suspension. I'm not sure if it has an anti-roll bar at the back?
Bearing in mid you are going to be putting 200bhp in it you really want to be able to stop and handle when you need to. As you also know most cossies are "claimed" to be 250+Bhp.
That considered a facelift 325 with a blown head or gasket would be dirt cheap, do a bit of work on the body if it needs it, take out the engine, ditch it and go from there. That way you'll have better brakes, suspension, arb's.
If you plan to change all of the above anyway then i can't see a reason why you can't use a 318, but more 325's break thats the only thing.
markybumpit
Mon Jul 25, 2005 12:54 pm
what about a 2.0i ? would that do ?
Guest
Mon Jul 25, 2005 1:00 pm
get on the phone to Zoom motorsport or Reyland :wink:
Geeman
Mon Jul 25, 2005 1:03 pm
nope... drums at the rear... you could really do with a broken 325 as it'll have all the brakes.
markybumpit
Mon Jul 25, 2005 1:42 pm
have you got the phone numbers for them ? in need of a cheap 325i then with a mint shell with broken engine.... anyone know anyone ?
Rearwheel_nick
Mon Jul 25, 2005 3:48 pm
id definately talk to zoom motorsport, i talked to john from zoom about it and he definately knows whats what when he comes to engine swaps he has put a cossie yb into an e36, so im sure he could put one in an e30 no problems
01564 794720 thats zoom motorsport number.
gareth
Mon Jul 25, 2005 10:04 pm
have a read through classic ford magazines... iirc the 2wd sapphire is the best donor. the entire engine loom can be connected on three or four wires on one connector. piece of piss!
it's the best one for mk1/2 escorts due to the simplicity so must make life easier.
Mon Jul 25, 2005 10:12 pm
a useful forum that is full of nutters into mad engine swaps etc is the one for Practical Performance Car www.ppcmag.co.uk
It should be full of people who will have done plenty of engine swaps
You defo want a 325 as the car for the better suspension and brakes. Consider a touring? Be different, oh and closer to 50/50 weight distribution, certainly will be with only a 4 pot up front :wink:
markybumpit
Mon Jul 25, 2005 10:36 pm
what the loom can be connected from a sapphire cos to an e30 325i with 3 wires ? which ones ? oh and dont like tourers sorry. so a cos engine would be less weight ? what would the car weigh then ? dont know what they are standard.
Rearwheel_nick
Tue Jul 26, 2005 1:51 am
not necesarily less weight, but better weight distribution, as the 6cylinder bmws have more engine weight ahead of the front axle which equates to not so great turn in, compared to a short engine (4cylinder) where more of the weight is further back.
markybumpit
Thu Aug 11, 2005 11:12 pm
hey peeps going picking up my cosworth running gear tomoz and also a 3.33.1 m3 rear diff. yey its all lookin good for the cab after all. dont know how long its gonna take me as im doin it myself. any help would be great. :D
markybumpit
Fri Aug 12, 2005 11:45 pm
sorry the diff is 3.25.1... if there is a big difference. anyway,so ive got it all. just gotta get round to fitting it all. lol should be fun.
markybumpit
Sun Aug 14, 2005 1:18 pm
hey peeps check this cossie engine in a e30 ??
Jon_Bmw
Sun Aug 14, 2005 2:29 pm
Still a bit criminal in my eyes, but good effort, how are you mounting it, are there three mounts, my experience with cossies is well none.
Custom mounts i'm sure but how are you making them, self fabrication or getting someone else to make them up?
Was there any clearence issues at all, gearbox tunnel??
glenbat
Sun Aug 14, 2005 3:16 pm
go for it marky! i had a 360bhp saph but sold it to move house :cry:
Aint a day goes past when i dont miss the action :wink:
Let us know when she's finished, I'll try and load up a pic of my ex...
glenbat
Sun Aug 14, 2005 3:19 pm
cue dagenham dustbin jokes... :roll:
markybumpit
Sun Aug 14, 2005 9:21 pm
thats a nice cossie mate, just never liked the sierra shape or i would have just got one of those, plus i wanna be the 1st to put a cossie engine into a e30 cab. :lol:
Eddiejt2
Tue Aug 16, 2005 11:02 pm
I do know of an E30 with a YB engine. It was featured in Revs (when it was a decent mag) YEARS ago. A white one IIRC, think it may have had M3 arches too, or may have originally been an M3.
So it can, and has been done.
glenbat
Wed Aug 17, 2005 1:08 am
There was an E30, black i think with a turbo'd YB lump in it about 10rs ago, was in the running for car of the year in Max Power (it was quite a cool mag when you was 16!!)
looked the nuts if i remember.... :wink:
cheers marky, she was cover girl for Performance Ford couple of yrs ago
markybumpit
Wed Aug 17, 2005 11:14 am
does anyone know the weight of a standard 325i and a 320i cab ? my cabs got a 6 pot 2ltr i with rear discs and antiroll bar. it also came with spax psx ajustable dampers and spax lowering springs, oh yeah ive put my 18s on it but it rubs on the drivers side rear ? my 325i sport didnt ? does anyone know why ? cheers
markybumpit
Fri Sep 02, 2005 12:53 pm
could anyone help please :D
