swirl marks in paintwork
e30-unit-soldier
Thu Feb 26, 2009 11:52 pm
I remember someone bringing up this topic before but cant find it!
Well whenever i get my car washed i can see very faint swirl marks in the paintwork maybe caused by washing car regularly i wanna know if anyone has used a polish that cures the problem ive used t-cut and Autoglym radiant wax polish but the sort the problem very temporarily................... :roll:
Thu Feb 26, 2009 11:55 pm
t cut might be the only solution but a lot of people dont like it as its quite vigorous
mattsbmw
Fri Feb 27, 2009 10:27 pm
To completly remove the swirls would require a machine polish.
By hand you could try some Autoglym Super resin polish, really work it into the paint, this will mask the swirls, then put some Autoglym Extra gloss protection over the top to make it last longer.
Fri Feb 27, 2009 10:29 pm
Is machine polish an expensive job? Got loads of swirls :(
mattsbmw
Fri Feb 27, 2009 10:32 pm
I would say so if done by a pro, looking at learning how to do it myself this summer.
Fri Feb 27, 2009 10:34 pm
I might get the whole car resprayed, will check out costs :)
mattsbmw
Fri Feb 27, 2009 10:37 pm
It will be cheaper than a respray, i think shine on detailing uses the forum perhaps send him a PM?
Fri Feb 27, 2009 10:39 pm
Will do thanks :) . Get it ready for the summer :D :cool:
e30-unit-soldier
Mon Mar 02, 2009 10:54 pm
mattsbmw wrote:To completly remove the swirls would require a machine polish.
I got a machine polisher what polish would be best? g3 or is that too aggressive?
mattsbmw
Wed Mar 04, 2009 8:27 pm
depends on how bad the swirls are and how hard the paint is, G3 is quite aggressive though.
e30den
Wed Mar 04, 2009 8:41 pm
g3 has it,s place [dustbin] but there are better products on the market.
powelly
Fri Mar 06, 2009 2:00 pm
I'm no expert, I do however no a bit, I have my own polisher, my personal preference of polish is the Menzerna range, others that spring to mind are, 3M or meguiars.
Check out Detailing World
Image Le Mans Classic 2006
asmith88
Fri Mar 06, 2009 3:14 pm
a machine polish will cost around 50 quid i think
Banjo1981
Fri Mar 06, 2009 3:25 pm
ImysE30 wrote:I might get the whole car resprayed, will check out costs :)
I'm thinking this too mate, let us know what sort of costs you're quoted.
Mine is well beyond a Machine polish unfortunately.
Mark-W
Tue Mar 10, 2009 8:26 am
I would charge around £5 a panel if im doing it, cant see any bodyshop charging over £7-8 to do it all over, thats flatting out any minor scratches with 2000 grade paper then polishing up with G3, then go over the whole car with G10, which is a finer grade compound, then i use Finesse, which is a 3M product, all over the car with a different mop head, will find out who makes them an try put a link up later, but its a soft sponge which is sort of lumpy, (bit vague sorry) this gets rid of swirl marks, then a quick wax, job done :D !!
powelly
Tue Mar 10, 2009 10:39 am
asmith88 wrote:a machine polish will cost around 50 quid i think
You may get a machine polish for £50, it will very likely look worse than when you gave it to them though, covered in holograms and probably still covered in swrls.
Removing swirls is a very time consuming process, it involves testing and using different abbrasives and pads, ideally needs to be done in conjunction with a paint depth guage. I'm still pretty novice at all this, it took me pretty much 5 hours of machining to get my car looking how it does, but it's by no means perfect. A pro detailer may well do it in half the time but never for £50.
Neil_M
Thu Apr 09, 2009 5:40 pm
I Agree :)
