cab rear seats
damoe30
can cab rear seats fit into a normal 2 door e30..if so how any is it a hard job.can you use the cab door cards..if any one has done this is it a hard job..pictures would help if any one has any..tanks
FormerMember
No you can't, because cabrio is quite a lot narrower than hard top.
Front door cards might fit 2d doors, not sure though.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
mrLEE30
yes you can fit cab seats in a coupe, but you will also need to swap the cab side cards and modify the rear parcel shelf to fill the gap.
unless done very well it wil look rubbish.
if you want the rear bucket seat style then go to a good upholsterers and have them made.
mrlee
mrlee
