How does your FMIC look behind the grilles?
Rotrex M42 Build - 285bhp little update
rix313
Sweeet
I'm baffled how I'm going to hose mine up lol.
e30_Turbo
- Boost Junkie
appletree
The 2'' ones are the same dimensions as the 2'' pipe as there to weld on the end like a flared fitting, pm me your details and ill send them tomorrow before i go away again. Id guess they'd be cheeper than the bends, but they will all be new sort payment later dude.
You only have to use one tb, the one with the linkage is the proper one the others abit thinner build quality.
appletree
Well another good bit done to the project, been realy busy at work but mangaed to get a few bits done.
After all my questions on the m20 clutch swop ive managed to get someware at last.
thanks chris w, town325i and odbod especialy.
Heres a few pic of the m20 b23 flywheel compared to the m40 one which most uk IS's seam to come with. bit of a weight differance.
Only 1mm differane from the crank face to the back of the flywheel, nothing to worry about.
Had to use a m30 starter in the end an mahine the back of the pinion gear down where the spring sit.
you can see where i had to turn the shamfer back on to the back of the pinion, also had to put the groove back in were the spring clip clamps to holed the spring on the shaft.
Now i can run an m20 b25 clutch which should take the torque.
i just have to use the e21 323 release bearing whih was £70! £20 cheaper than the sach clutch kit that came with a 325 release bearing which unfortuanly is the wrong size which is why i need the e21 one
e30_singh
That is some craftmanship!
Hats off for the build so far!
rix313
How much does the fly wheel weigh mate?
appletree
The m20 one is about 16lb, but i have the lightest type theres one witha slight lipo on the back thats more common that weighs 19lb.
rix313
Mine weighs 14.8
How many sheds you got
appletree
The thing is that the m20 has all the weight near the centre of the wheel which helps more than the weight loss its self.
Bought these off ebay last week, Supertech valves with a nitrid coating. there designed for boosted aplications and are solid rather than the sodium filled so there shouldnt be any trouble with them when they start to work hard and get hot in my set up
coatinghttp://www.nolimitmotorsport.com/supertech/valvetrain.html
Also bought the retainers, seats and dual springs that the guy was selling. pics to follow
Only problem i can see is that the supertech valves are 1mm thinner on the stem than the standard ones so i will have to get some guides/seals to suit. any ideas?
Gunni
M50/S50 guides might well work, the S50B32 has 6mm guides.
appletree
Got some progress on the flywheel swop, got another engine and gear box bolted up upside down and bolted all the flywheel assembly on to it with the modified starter, connected a set of jump leads up and and it burst in to "life"/ turned over
No i know it all works i can get it properly bolted up.
i had to turn it upside down as there was no way of sitting it on the floor with the sump still on.
The head was already off when i got the engine off kedge and someones glued the sump plug up so its still pritty full of oil to.
Bit rough but it proved a point
rix313
Watched a program once was based in India, they just took an enine out of a warehouse, plonked it on the floor, poured some petrol in it and just started it on the floor
Hows my crank pully?
appletree
The pully bit is done and the ally bits bored out ready, should be done for friday hopefully, bin away for two weeks with work
smith4130
was biddin against you on ebay..... nearly.....
best of luck with the build.....
appletree
Reserve was 200 and same with the springs and seats.
Shells and rods are back on again.
What are you building? 2.1 or boosted?
smith4130
chargecooled m45 with a simlar manifold as the one your running. it's my first build and takin my time.
fair play with the build, another great thread....
appletree
Thanks, if you need any info let me know, your engine should be ok as standard though, mine was and i drove it on the autobahns to the ring an did 4 laps there with no probs and it got some A-buse!
ShepsEvo3
- Master of go faster
I am working my way on both... on the same lumpappletree wrote:What are you building? 2.1 or boosted?
www.sabre-tuning.co.uk
smith4130
http://cgi.ebay.com/ebaymotors/Turbo-Wa ... 240%3A1318
sorry appletree i hope you don't mind me doing this on your thread, but i would like your opion on this....?
appletree
Fine, no probs, theres sum simular ones one uk ebay sometimes for £79-£99. There a much easyer solution than what i made but to be honest if your going to be mounting it in a position you could pipe to that type of cooler id would use an air to air intercooler instead, loads out there an easyer system to install.
Also if posible i would suggest trying to put the throttle upstream of the charger so you havent got to add dumpvalves at more expense.
hoshy
- E30 Zone Wiki Guru
Having been through the mill on this, 2nd time around I'd listen to Matt here. Downstream throttle on a positive displacement charger is a pain.appletree wrote: Also if posible i would suggest trying to put the throttle upstream of the charger so you havent got to add dumpvalves at more expense.
appletree
How is yours going now hoshy? i was down the winning post again on thursday but didnt finish till 11 or id have given you a call for a pint
hoshy
Cool. Give me a bell next time mate. After I hooked in the proper air intake I had much better IATs so I gave her a bunch more advance and she was running really well. Still get some slight resets but noticed that they only happen when I try to run way too little advance (sub 10deg) so with the cooler intakes it's not been a problem which is nice.
Need to get proper H4 replacement light(s) though as it's not gonna pass an MOT with one headlamp removed
smith4130
yea... i read a few threads on the upstreme throtle.... mixed opinions... the roots sc doesn't lend itself to it as well as your centrifugal... but the one that kept commimg up was hammer action... i would have gone centrifugal only budget limitation.
im going to recirc from the inlet maniflod to post throtle with a 40mm dump valve and dumping excess with a vag recirc 7psi, somthing like the dasc.
i'm trying to keep the heat low as possible.... runing the chargecooler in conjunction with a front mounted alu oil cooler with two fans and additives.... read a few bits on vr6, lotus and US forums coulpe of reports of 20bhp increase.
was trying to get through to emerald.... their is no answer, have they moved....?
appletree
You seam to have a good idea where your going. Emerald are still at the same place, sometimes its easyer to email them. Dave always checks his email and replys before he starts the days mapping. Ive got full wiring diagrams for an motronic to emerald adaptor plug.
rix313
Ash I got something coming that will be of some major help RE: head lights, will advise ;)
hoshy
Wouldn't mind seeing those diagramsappletree wrote:You seam to have a good idea where your going. Emerald are still at the same place, sometimes its easyer to email them. Dave always checks his email and replys before he starts the days mapping. Ive got full wiring diagrams for an motronic to emerald adaptor plug.
smith4130
cheers...
just wasn't sure about cooling beging good enough for the cost out lay, and the heat generated.
i got to read back over your m45 build again.... and get a couple of questions together.
i'll try emerald again next week.... the hole ecu side of it is frying my head.... been avoiding it for ages but the time has come to start readin up more on it.....
Kedge
appletree wrote:The m20 one is about 16lb, but i have the lightest type theres one witha slight lipo on the back thats more common that weighs 19lb.
Not been on here for a long time and looks like you've made some great progress with the project from the quick glance i've just had of the thread
Just made me realise i need a good slap for selling my iS!
appletree
Ohh what you got? Please be plug and play... The lights is one thing i havent been looking forward to making an adaptor/holder for.rix313 wrote:Ash I got something coming that will be of some major help RE: head lights, will advise ;)
Ill post some pics of the diagrams up when i get a chance. You just need to add a loom for the map sensor and the manifold temp iirc.
tim_s
Ash/mat, give us a buzz if you do head for drinks out your way - I'll bring the 2.1 along
Looking forward to this Matt, some great progress here! Here's hoping for another epic build thread like the last one...
hoshy
Will do, Tim.
Ric - keep us posted on the lights
rix313
It isn't looking pretty at the moment lol! gashed up a set of headlights so far doing R&D, just waiting for my new lighting units which should be here by the end of the week and I can then get some pictures up and report backappletree wrote:Ohh what you got? Please be plug and play... The lights is one thing i havent been looking forward to making an adaptor/holder for.rix313 wrote:Ash I got something coming that will be of some major help RE: head lights, will advise ;)
tim_s wrote:Ash/mat, give us a buzz if you do head for drinks out your way - I'll bring the 2.1 along
Can I come
rix313
appletree
Nice! so is that dip, main and sides then?
Got it running to day, the first vid, running with the trottle set up wrong.
[youtube][/youtube]
This is later tonight once it had been idling for a bit and the enigne was up to temp, still got a 3000rpm limit for the first 60miles to run the charger in.
First i forgot to reset the throttle limits so the ecu thought the throttle was open but it was shut so it was over fueling, anyway heres the vid of it running properly. need to tidy the bay up now i know it all works ok.
[youtube][/youtube]
[youtube][/youtube]
[youtube][/youtube]
