Thanks!
Touch-up paint & a couple more bits please!
Ziggy
Oxford Green Metallic - for a '96 E34 520i se touring.
Thanks!
Thanks!
Cotswoldbmw
Afternoon
Price is £9.96 inc
Regards Karl
Price is £9.96 inc
Regards Karl
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
Ziggy
Could I have some prices on a couple more bits please - must give you a call tomorrow!
Also for the '96 E34 320i SE touring:
water pump & o-ring (& the 2x m6 bolts for removal of the pump according to the bentley manual?!)
alternator/etc "poly-ribbed belt" & tensioner
oil filter
air filter
spark plugs
Cheers!
oil filter
air filter
spark plugs
Cheers!
Cotswoldbmw
Sorry on the late reply but can i have your car details please
Regards Karl
Regards Karl
Cotswold BMW Parts
01242 335365
01242 335365
Ziggy
Last 7 digits do you? GC43179
1996 E34 520i touring SE, manual.
Slightly revised list now;
Oxford Green Metallic touch up paint
AC belt
AC belt tensioner
Accessory drive belt
Accessory drive belt tensioner
Accessory drive belt idle pulley
Could really do with the bits ASAP...
AC belt
AC belt tensioner
Ziggy
BTTT.
Cotswoldbmw
Afternoon
A/C BELT £14.97
A/C TENSIONER £63.01
DRIVE BELT £23.64
With the tensioner i need to know if its hydraulic or mechanical
Oil Filter £8.64
Air Filter £17.04
Spark Plugs x6 £19.88
Waterpump £ 86.62 inc I will refund you £16.49 when you return the old unit
There are 2 different alternators 1 is a 80a or a 140 a i need to know sorry.
The touch up pencil is £8.72
All prices include vat,discount and delivery to mainland uk
Ref No 39045
Regards Karl
A/C BELT £14.97
DRIVE BELT £23.64
Oil Filter £8.64
Air Filter £17.04
Ref No 39045
Regards Karl
Cotswold BMW Parts
01242 335365
01242 335365
Ziggy
Karl, cheers for all the help!
I think I've worked out what I actually need now. I'll give you a call first thing monday morning - just writing this here so I can refer to it then really.
I didn't realise that the pulleys were a separate part from the tensioners themself, but having pulled it all apart I 'get it' a bit more!
So I'll go for the following:
Oxford green touchup paint (£8.72)
AC belt (£14.97)
Accessory drive belt (£23.64)
2x tensioner pulleys (AC & acc drive being the same part - 11281748131?)
1x acc drive idler pulley (11287841228?)
& I can't find it on realoem, but I assume there should be a plastic cover behind the o/s headlamp?!
AC belt (£14.97)
Cotswoldbmw
Done over the phone
Cotswold BMW Parts
01242 335365
01242 335365
Ziggy
Indeed! Cheers Karl
Ziggy
Both packages received, fitted & nice and quiet now! Cheers!
Another random thought was that I didn't get much history with my E34, just a (stamped up) service book... Is there likely to be any info stored on a central system eg spec, purchase price, recalls, service history even? & if so, is there any way for me to go about getting hold of it?!
Thanks again
Thanks again
Cotswoldbmw
Best thing todo is call the dealer who did the services to find out that info because of the age of the car all that will be on the old system (DMS) which i cant get into sorry
Regards Karl
Regards Karl
Cotswold BMW Parts
01242 335365
01242 335365
Ziggy
Cheers - will do
