E36 m3 evo brakes on e30 m3
dicko
Just wondering Have any of ye tried fitting e36 m3 evo brakes on a e30 m3 .
the reason i am thinking of this is i still have the donor car for the conversion beside me
BadDave
You could try giving Jhonno a PM
He's been on about doing the same thing to his 5 stud conversion on the 24 valver.
I don't know how far he's gotten with it yet though, but could be worth a try.
HTH
HTH
jaistanley
The calipers will go straight on..
The disks can go on if you get special hubcentric adapters behind the disk, though this means you need E36 offset wheels. The option that was going to put on my car and jhonnos is a wilwwod disk of the correct dimensions, with custom machined aluminium hats. This would retain the E30 M3 offset wheels.
HTH
Jai
HTH
Jai
e21Jason
This topic is well coverd on s14.net and muzzi motorsport sell the spacers
Jason
Jason
- Homo Hair
custom hat and rotors works out about £375
new m3 discs from bmw are about £140 each + cost of spacers..
dicko
Thanks lads
dicko
Jason I emailed Muzzi today and they said they dont do spacers for the e30 m3 .
Jhonno where did you get your spacers ,
I take it that e36 hubs wont fit e30m3 stub,s?
Karan
just wondering if you're spending so much why not just buy a porsche 4/6pot kit by Mov'it?? or is that a lot more???
dicko
Its just I have the e36 m3 evo donor car and was hoping to use the brakes off that ,
I guess spacers will be cheaper than disc's and caliper's ( I hope)
- Homo Hair
Because E36 setup costs about £400, and fits behind more wheels..
- Homo Hair
SBi used to..dicko wrote:Jason I emailed Muzzi today and they said they dont do spacers for the e30 m3 .
You need a 13mm spacer behind the disc to bolt it all straight on..
I am going 2 piece bell and rotor setup as it is lighter and I can have a spacer built in, sadly my M-Systems don't clear the calipers
No they wont, completely different setup
dicko
Thanks Jhonno do you have a link for SBI i cant find anything ,
I take it that works for front and rears
UweM3
I have a drawing and 3D CAD model for the spacer. But you have to be aware that your track will increase 12.5mm EACH side. But it will fit under 16" rims, you just need to make some spacers for the rear and run E36 wheel offset
jaistanley
Or you could fit the MCoupé swingarms and get matching brakes for the rear (The MCoupé rear brakes are the same as the E36M3).... This was my original plan for my car, but now I'm fitting E36 front components.
ian332isport
Around 2K these daysKaran wrote:just wondering if you're spending so much why not just buy a porsche 4/6pot kit by Mov'it?? or is that a lot more???
