1) what's involved in swapping it all over from the 320i to the 325i?
2) will i need to swap the radiator over and if so will the 320i one be ok with the 325i lump?
3) what is the score with regassing? at the moment the aircon doesn't work in the "donor" car and i want to re-gas it cheaply to check it all out before i undertake a double dash removal on order to swap everything over!!!
4) what do i need to remove other than the obvious parts? any relays, controls etc?
5) the big one... i am looking to fit a M30 3.5 in the next year or so.
heeeeeeeeeeeeelp!
