Removing waterpump
everhard
Mon Feb 09, 2009 4:23 pm
Hi guys
Wanted to remove the water pump today but could'nt
Get the fan assy off!!!! :x
How do you undo the 32mm nut with out the pulley moving :cry: !!!!!
(i now you have to turn it clockwise to undo)
Don't mind two much!!
But three much is two much!!!!
jslot
Mon Feb 09, 2009 4:25 pm
Hit/tap the spanner with a hammer.
Also, just in case you didn't know, it's a reverse thread
leeparkes
Mon Feb 09, 2009 4:29 pm
You should be able to 'shock' it undone by hiting the spanner with a hammer,unless its been thread locked
everhard
Mon Feb 09, 2009 4:43 pm
Cheers guys
I,ll try lumping it!!! :D
**BANNED**
Mon Feb 09, 2009 4:54 pm
To stop the thing from turning as you belt it with your Birmingham spanner,put an old drive belt around the pulley twisting it tight with a short bar(screwdriver)to wedge it.
Youth is wasted on the young.
