e30 e36 diffs
- 313ross313
just wondering if i can put a e30 diff in a e36 any one no ?
No, they are different casting's with different mounting points...... Except the compact and Z3, which use a very similar rear suspension set-up to the E30 so they will fit but are a very low ratio, good for M50 swaps if you use the E36 gearbox.
