m20 or m42
well you already have an M42 gearbox so may aswell use that.tinnaM42 wrote:wot u reckon it would cost?
Engine will be about £250 on average then you probably have another couple of hundred quid in engine mounts,exhaust manifold,servo etc.
				leeparkes
Answer to the question id go for the M20
If i was in your shoes id go for M50,
as eko said you already have the correct g/box and its not all that difficult!
m50b25 ftw!  although otherwise i would say m20b25 - makes better noises than m42!
- **BANNED**
Exhaust is your biggest problem,if you are handy and good with a welder you can make your own. The custom built one is very good but also very expensive.eko wrote:well you already have an M42 gearbox so may aswell use that.tinnaM42 wrote:wot u reckon it would cost?
m50
m20 if you have to
						m20 if you have to
Ive got an m20 on mine and im contemplating gettin an m50. As im no expert im wondering
would it be a straight forward swap or would i need to change gearbox, wiring loom and get a
custom manifold etc. would i need custom mountings aswell and is it worth swapping?
				GrindCulture
I wouldn't replace an M42 with an M20, ever. Stick an M50 in it, 4 valves per cylinder is the right way to go!
									Not in E30s any more
i have a m20,b20 prop if needed?
i'm just putting the m20 flywhhell clutch and starter on mine,it's chipped up and has a pan filter but i'm going to do all the easy mods on it before i decide where i'm going with mine.
i like good mpg combined with good speed.
a hard combination to achieve.the fly and clutch will give much better response [throttle]
+ a yard full of scrap turds
				Bob_S
yes, all e30 boxes and props have the same fixtures and fittings so all are interchangeable within reasontinnaM42 wrote:if i use the m40 diff and a m20b25 box would a m20b25 prop fit at both ends??
Bollocks to this 24v scrap!
