h7fal
Post
Wed Jan 28, 2009 5:41 pm
I only put about £7 worth in then noticed and topped it up with about £40 worth of diesel. The tank also had a couple of gallons of diesel left in it.
Any ideas if I'll get away with it? What should I look for if things go wrong?
I feel a right tit
Ziggy
Post
Wed Jan 28, 2009 5:55 pm
What car is it? If it's something old and primative, you won't even notice - people used to add petrol to stop diesel freezing in the winter (less need with modern fuel). Doubt it'll do any harm on anything modern either...
DHFiS
Post
Wed Jan 28, 2009 6:02 pm
When I did it in an old van the engine lost almost all power and would only rev to about 1000rpm plus huge clouds of white smoke from the exhaust. Drove it back to work 1mile, pumped it out and refilled with diesel - no damage.
h7fal
Post
Wed Jan 28, 2009 6:06 pm
Ziggy wrote:What car is it? If it's something old and primative, you won't even notice - people used to add petrol to stop diesel freezing in the winter (less need with modern fuel). Doubt it'll do any harm on anything modern either...
It's a 57 plate Honda CRV. I've been Googling the question and it sounds like I'll get away with it. I'll just keep topping up to dilute it further.
Post
Wed Jan 28, 2009 10:17 pm
It'll be fine. Put 15 quids worth of unleaded in my 2006 astra before i realised
. Brimmed it with deisel and it's been fine. I've done it a few times now. Only once though, where I filled the f*cker from empty and had to have it drained.
Run it to 3/4 full and top it up. Keep doing that 3 or 4 times then just go back to normal fill ups.
town325i
Post
Wed Jan 28, 2009 11:53 pm
on some new diesel cars if you put a fair amount of unleaded in it can damage the fuel pump and give you a high repair bill
maxfield
Post
Wed Jan 28, 2009 11:56 pm
Doubt £7 will even come close to damaging anything.
town325i
Post
Thu Jan 29, 2009 12:05 am
maxfield wrote:Doubt £7 will even come close to damaging anything.
no i dont think it will i missed that bit
bodger
Post
Thu Jan 29, 2009 12:06 am
not at todays fuel prices
, what you burning about in now young max , what happened to the touring
si-
Post
Fri Jan 30, 2009 2:00 pm
you'll be fine,
went to recover a 57 plate x5 the a while ago the guy had done the same thing put in 15quids worth of petrol realised then, brimmed it with diesel and off he went not a murmor from the engine
RM2186
Post
Sat Jan 31, 2009 9:59 am
Bet you won't do that again though.....
I didn't
1987 Tech1 325i Sport
h7fal
Post
Sat Jan 31, 2009 10:09 am
RM2186 wrote:Bet you won't do that again though.....
I didn't
All seems fine, have done over 100 miles since I did it and topped it up with another tenners worth of diesel. Cheers for the responses!
p.s. I'm not going to bother with the fuel filter thing, it's a company car......which is one reason to be wary of buying an ex-fleet mobile, people like me drive them into the ground
