Does anybody know where the coolant level sensor is located on me 325i ? I reckon mine is boogered. I have a 318i for spares. Are the sensors the same ?
Cheers Dudes !!
Coolant level sensor location?
georgen
01' 330ci Sport
02' 530i Sport Saloon
52' 330i Individual Touring
dazleeds
- old skool raver
not sure if same but i think its the one in the expansion tank mate nearest the headlight take off plug and unscrew but beware it may fall apart mine did lol dnt think they cost much new mate Daz
www.oldskoolfantasy.co.uk
georgen
Cheers Daz, will have a lookie tonitedazleeds wrote:not sure if same but i think its the one in the expansion tank mate nearest the headlight take off plug and unscrew but beware it may fall apart mine did lol dnt think they cost much new mate Daz
01' 330ci Sport
The type that fit with the connector end upwards (e.g 325 type) is different from a 318i one which fits with the connector downwards, in the bottom of the header tank on the rad.
If you fit the wrong one, it will indicate coolant OK when it's low, and coolant low when it's full.
GSF and Eurocarparts are both capable of supplying the wrong one!
georgen
[quote="Brianmoooore"]The type that fit with the connector end upwards (e.g 325 type) is different from a 318i one which fits with the connector downwards, in the bottom of the header tank on the rad.
quote]
Aah, cheers Brian. Good info there chum !!
quote]
01' 330ci Sport
