Hi please can you give me prices on the following parts
HOLLOW BOLT 11421280914
GASKET RING 07119963441
O-RING 11421714764
FLANGE 11421265669
O-RING 11421265670
r12-r134a conversion 82319067394
DOUBLE TEMPERATURE SWITCH 61311378073
GASKET RING 07119963201
RADIATOR 17112241912
FAN SHROUD 17111709312
BRACKET 17111709333
WATER HOSE 11531722218
AIR INTAKE TUBE 51711966439
GAS PRESSURIZED SPRING 51251932333 (x2)
GAS PRESSURIZED SPRING 51248103180
EXPANDING NUT ST 6.3 64121379221 (x4)
Hex head screw 07119916965
BODY NUT 16111152613
HEX HEAD SCREW ST6,3X19-C-Z1 07119916970
HEX HEAD SCREW ST6,3X25-C-Z2 07119916973
EXPANDING NUT ST 3.9 51711874203 (x4)
GASKET 51711825972
GASKET 64111375719
I can't find the part numbers for 2 expanding nut or cage nut which fit a hole approx 11mm square
It might be one of (no.9) 63171386461 and 65131379744 on this link as they don't have a size
http://www.realoem.com/bmw/showparts.do ... g=41&fg=65
The place i'm refering to is the 2 bolt holes on the aircon dryer (part 18 ) as shown on this link
http://www.realoem.com/bmw/showparts.do ... g=64&fg=60
Neil
Prices Please
neilh
1988 320i Convertible in Apline White II
Factory fit ABS and Leather
Currently retrofitting OBC, Headlamp washers, Cruise Control and Aircon
Cotswoldbmw
Morning Neil
Your 1 package left friday and the other is leaving today
Regards Karl
Regards Karl
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
