Can I fit a performance clutch for a 318 or M3 to my 325?
mhobday25
Sat Jan 24, 2009 2:35 pm
Hi, anybody know if I can put a performance clutch that is advertised for an M3 or a 318i on my 325? Are they the same? I have found some great spec'd clutches online, but none for a 2.5
maxfield
Sat Jan 24, 2009 2:38 pm
They're all different as far as I know....
Why do you want an uprated clutch anyway?
Theo
Sat Jan 24, 2009 2:39 pm
No, they are different diameters.
mhobday25
Sat Jan 24, 2009 2:44 pm
I've got to change the clutch anyway, and GSF want £94 for a standard one with my brothers trade discount, so I might aswell go for a performance one. That way I can play about with the HP in future worry free. Would you just fit the standard one then?
maxfield
Sat Jan 24, 2009 2:46 pm
Unless you intend on strapping a massive turbo then the standard clutch will be fine.
mhobday25
Sat Jan 24, 2009 2:47 pm
Ok then, cheers. Il just get that one then. How much BHP do you think they can handle?
Chris
Tue Jan 27, 2009 10:35 pm
2-300hp if your gentle
Chase007
Tue Jan 27, 2009 10:47 pm
Chris wrote:2-300hp if your gentle
Like a women say's dont push it in pull it up too hard winkeye
Turbo-Brown
Boost Junkie
Wed Jan 28, 2009 7:15 am
It's not power that will cause a clutch to start slipping, it's torque.
You can make as much power as you like, as long as the torque doesn't exceed the clutch's spec.
