is badge
asmith88
previous owner took the is badge of my 318 is, anyone reccomend how to put it back on?
iwould use glue but is there a good brand/type?
cheers.
cheers.
adit
don't use glue! it can affect the paintwork. i use double sided "spongey" tape (£1 per roll from mr.cheap/poundland, etc), cut into little pieces and stuck at various points around the back of the badge. it works perfectly well and can be removed without too much difficulty if you stick the badges in the wrong positions/need to remove them!
armanib
- **BANNED**
ERMM ASK BMW THEY HAVE NEW ONES BUT I THINK THEY ARE SLIGHTLY DIFFERENT SIZE
asmith88
yea i was gona use double sided tape, just thought it would be awkward to cut/stick and fit. but il try that tomorrow thanks
armanib wrote:ERMM ASK BMW THEY HAVE NEW ONES BUT I THINK THEY ARE SLIGHTLY DIFFERENT SIZE
sounds like your shouting
armanib
- **BANNED**
Oh yer sorry
adit
he doesn't need a new badge, he wants to know how to stick the one he has, back on!
aj_mckay
3M make very good sticky stuff that is often very slim so great for sticking badges etc. on. Oh, and your avatar pic is mahooosive dude!!!
Cook318IS
your avatar is huuuuge asmith! dont new badges come with adhesive on the back?
sati
yes double sided tape will work as long its the stong type and the surface's are clean, but be careful if useing an jetwash it will rip the badge off. so i say go with 3M double sided Tape. and an side note resize your Avatar to no more then 200x200 pixles
m4xos
remember to clean the badge before you put it back on the car!!
stupid tip but a hell of alot easier!!
asmith88
yea, sorry bot the avatar, i was having a lot of difficulty with that, lol,
got 1mm double sided pads from halfords, cleaned everything up, stuck it on, its had a wash since and its fine, so alls sorted now.. thanks for your help.
DublinBMW
I am in the same boat, the PO took the model badge off the back.
How long does the double sided tape stick for before it starts to go?
asmith88
dont know but i got the 1mm stuff from halfords and i havent had any problems, its stuck on prety tight and i cant see it coming off inthe near future. they give you plenty.
