M50 swappers - what drop are you running?
I'm hoping to get hold of some H&R 60/40 springs for the touring, will have B6 front dampers fitted.
Am I aiming for trouble with the sump?
Wilson325i
It has been so long i can not remember what springs i have on there.
but its a -60mm all around, but i will be going -40mm so i can get some 225 or 235 on the back to cope with the power of the S50.
to answer your question, (are you looking for trouble with the sump?) Yes you are. i have 18"s & -60mm and still it seats scary low to the ground (the sump).
baptie0
i have a 40mm drop front/rear, spax springs & kyb shock absorbers.
my sump has made contact a couple of times. i am going to make a guard out of 10mm alloy plate.
eko
- Old timer
318is H&R kit on mine,60/40 with no problems.
Always in the back of my mind when approaching speedbumps though
benjy
I run a 60/40 KW kit on my touring. Still got an inch or so ground clearance
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
Wilson325i
where can i find a set of these B6 shocks that i keep hearing about?
baptie0
what about euro car parts, i think i remember seeing a catalogue with them in it.Wilson325i wrote:where can i find a set of these B6 shocks that i keep hearing about?
I don't know mate, I got mine secondhand from Si13, they look like new thoughWilson325i wrote:where can i find a set of these B6 shocks that i keep hearing about?
B6 if you want to go 60mm or more
B8 for 35-40mm drop
BigBavarian
Im running a 60mm drop all round, new bilstein shocks and rolling on 15" bbs deep dished rims, my sump is about 2.5 to 3 inches from the tarmac and ive not had any problems... yet
Richard
Richard
Bob_S
35mm H&R's here and it's annoyingly low..
Dafs was round before and was on about removing his 60mm springs for fear of his sump.. I dont blame him as mines worrying me
Bollocks to this 24v scrap!
I had 60 spax springs on the front but it was more like 80, they were too soft TBH, I ended up raising the spring seats to lift the front end 10 or 15mm
You just have to keep it in the back of your mind when driving on unknown roads
On 16's
On 16's
- Homo Hair
Don't know what mind is, but I have just under 3" of sump clearance.. Always have too be be mindful of it!
Daf318is
Just been out to take a photo of mine - it has -60mm Spax on it which as Bob_S said I'm going to change. The sump is even lower than the splitter
Sorry about my shoddy photography but there's about 80mm ground clerance between floor and the splitter
Now driving an E46 320D touring
Those springs are lethal with M50 weight!
Daf318is
They are coming off before it goes on the road! I have a speed bump on the way to work and it will never make it over that
I'll post some before and after pictures when I put the 40mm springs on. so you can have a comparison with the same car and camera angle (possibly)!
What springs are you going to use?
Bob_S
H&R I am hoping dan! I lost my iS splitter the other week, had a tank slapper and think I pinged it off on the curbstone
eko
- Old timer
Heres my first M50 on 60mm spax springs,dangerously low
[/img]
[/img]
They seem to be hard to get ATM, one of the sites lists Eibach cheaper than H&R!Bob_S wrote:H&R I am hoping dan! I lost my iS splitter the other week, had a tank slapper and think I pinged it off on the curbstone
I think I will give the 60mm front drop a miss then and go no more than 40. I'm planning on staying on 15's.
I have over 20 speed humps to contend with to get to work
Dont buy spax then, mine were only any good once id fitted the inverted billies, still a bit soft but ok for a daily driver, even so I wont use them again
- Homo Hair
ACS Springs.. Didn't realise I was about -60mm.. Ive not caught the sump *Touch wood*
- **BANNED**
My car is STILL up on axle stands
but I reckon the sump is at least an inch lower than an M20 one,and slightly further forward,think I will have to mod the front undertray today before it goes back on.Go more than 40mm lower at your peril Beemerlad,I have driven on your estate!!
Youth is wasted on the young.
- **BANNED**
Further to this,my front undertray has re-fitted without mods,just touches the front of the sump,but the sump sits around half an inch below the undertray,the M20 is level with it.daimlerman wrote:My car is STILL up on axle standsbut I reckon the sump is at least an inch lower than an M20 one,and slightly further forward,think I will have to mod the front undertray today before it goes back on.Go more than 40mm lower at your peril Beemerlad,I have driven on your estate!!
