Windscreen washers
jack148
Tue Jan 13, 2009 2:42 pm
Hi Guys,
I have had a problem with only one of the washer jets working, so today after it stopped raining I decided to have a look.
What is the T piece in the line supposed to do. Yeah I know it splits the water to both washers, but I'm sure it does more than that. Mine squrts water out of 2 holes in the T piece rather the directly to the washer jets. I'm guessing this shouldn't happen and the T piece is F***ed!
Any thoughts?? Can it be repaired or do I need a new one??
Jack
abelai
Tue Jan 13, 2009 3:41 pm
They are one way valves available from BMW. Mine died and did the same, can't remember how much they were.
If I can't fix it I'll f**k it up so bad nobody can!!
Tue Jan 13, 2009 4:53 pm
sure i got mine from ecp less than £10 i think. :D
jack148
Tue Jan 13, 2009 6:21 pm
Thanx fellas!!
Anyone got one knocking around for a couple of £££???
Tue Jan 13, 2009 7:16 pm
magpie wrote:sure i got mine from ecp less than £10 i think. :D
Or about half that from BMW, IIRC.
Check with the zone's genuine parts forum.
Banjo1981
Tue Jan 13, 2009 10:32 pm
I've got the same prob, currently £3 at gsf.
jack148
Wed Jan 14, 2009 8:44 am
Thanx!! I'll get onto Karl today. winkeye
Chris36
Wed Jan 14, 2009 9:49 am
Had this problem to, just drilled all 3 ends, and aroldited the 2 small holes. Good as gold.
Thu Jan 15, 2009 12:06 am
Chris36 wrote:Had this problem to, just drilled all 3 ends, and aroldited the 2 small holes. Good as gold.
Words fail me!!
robbo86
Thu Jan 15, 2009 11:25 pm
I had this problem, replaced the pressure regulator with another with failed even more disasterously then the last with 6 months! Bloody crap they are!!! My fingers were to big to close the grips for the washer hoses back inside the bonnetand I had to leave it hanging out :mad:
jack148
Fri Jan 16, 2009 7:32 am
Ordered a new T piece from Karl at Cotswold for £4.15 delivered! :D :D
mdpe30
Fri Jan 16, 2009 9:42 am
New here. I need a T piece also. Anyone provide details for Karl?
Fri Jan 16, 2009 6:44 pm
Karl, (amongst others) = zone' BMW genuine parts dept.'
Chris36
Fri Jan 16, 2009 8:43 pm
Words fail me!!
This was only a temporary fix by the way!!! Sorted now with a replacement!!
tomtomiS
Fri Jan 16, 2009 9:45 pm
Words fail me!!
:lol:
