Interesting Murran. Unless I'm mistaken, in law, the content of the MOT test is derived from the Construction and Use Regulations, which are pretty vague about 'view' requirements:murran wrote:magic trees rfr 1e
http://www.motuk.co.uk/manual_830.htm
magic trees, when hanging are encoraching on your view out of the swept area by more than 40mm!
should really give the presenter opportunity to remove it before failing. but meh.
if the car hasnt failed on anything else i do just move the magic tree but if im already failing it i just add it on!
VISION
View to the front
30.””
(1) Every motor vehicle shall be so designed and constructed that the driver thereof while controlling
the vehicle can at all times have a full view of the road and traffic ahead of the motor vehicle.
(2) Instead of complying with the requirement of paragraph (1) a vehicle may comply with
Community Directive 77/649, 81/643[, 88/366, 90/630]72 or, in the case of an agricultural motor
vehicle, 79/1073.
(3) All glass or other transparent material fitted to a motor vehicle shall be maintained in such
condition that it does not obscure the vision of the driver while the vehicle is being driven on a
road.
Similarly, under 'Driver's control':
104. Driver's control
No person shall drive or cause or permit any other person to drive, a motor vehicle on a road if he
is in such a position that he cannot have proper control of the vehicle or have a full view of the
road and traffic ahead.
but this is not actually regulating something hanging from the rear view mirror.
I wonder where VOSA got their 40mm stipulation from - do you think they just made it up?
Also, the MOT is mandated in law to test the 'glass and field of vision' but only as stipulated in regulation 30. A magic tree is NOT part of the windscreen / glass and arguably, the phrase 'windscreen sticker or other obstruction' necessarily refers to another obstruction ACTUALLY ON THE GLASS.
Interesting to note that the manual does nonetheless include sun visors, but also that despite such an exhaustive list of considerations, items hanging from the mirror are not mentioned.
I reckon that you might be fooked if you fail a lawyer for his magic tree!
