Schrick Camshaft
Diesel
Post Thu Jul 14, 2005 10:19 pm
What do you recommed for best bhp gain and low down torque for a 325 sport, and where in the uk can i get them form?
Schrick Camshaft - 272 degree
or
Schrick Camshaft - 288 degree
any info apreciated
Dan318-is
Post Thu Jul 14, 2005 10:21 pm
i would recommend 272 mate, although the 288 one will probbaly gain a few more brake, the idle will be very lumpy due to high long lifts of valves.
hope this helps
TW166Y
Post Fri Jul 15, 2005 2:38 am
:yeahthat: 272 matey is the one and eveyone will say the same, :wink:
Diesel
Post Mon Jul 18, 2005 10:02 pm
cheers for your help guys
Dan318-is
Post Mon Jul 18, 2005 10:03 pm
ne time 8)
TW166Y
Post Tue Jul 19, 2005 2:34 am
:wink:
hogweed
Post Thu Jul 21, 2005 6:20 pm
272 doesn't mean anything though - do you mean 272/272 or 284/272?
E30 custom active sub for sale - PM for details
TW166Y
Post Thu Jul 21, 2005 8:21 pm
Diesel wrote:What do you recommed for best bhp gain and low down torque for a 325 sport, and where in the uk can i get them form?
or
any info apreciated
Diesel knows and after all he did ask, he fully understands :wtf: :chuckle:
Diesel
where is the best place to get them in the uk?
TW166Y
Post Thu Jul 21, 2005 8:31 pm
on a more serious note now, Schrick 272-272Ԛº duration, 11 mm lift. Smooth idle. Best when used with performance chip. Dual valve springs required. this cam can also be used on auto's
Schrick 288-288Ԛº duration, 11.4mm of lift. Lumpy idle limits application to manual transmission models only. Works best with performance chip, free flow intake and exhaust systems. Korman Dual Valve Springs and titanium retainers required. obviously the 288 will produce more bhp but is really only for track use, 272 is perfect for road use, hope this helps you a little better????
TW166Y
Post Thu Jul 21, 2005 8:35 pm
Diesel wrote:where is the best place to get them in the uk?
try ebay dude if you have no luck there, there is a guy in germany who sells on there and he is quite cheap, about Ԛ£230 i think mate :wink:
Diesel
Post Thu Jul 21, 2005 9:50 pm
Ԛ£230 not a bad price!!
cheers again for your help guys
hogweed
Post Thu Jul 21, 2005 10:03 pm
My point was that if you say 272, you could mean the 272/272 OR the 272/284, which several Zone contributors use... why only compare the two extremes?
TW166Y
Post Fri Jul 22, 2005 1:48 am
hogweed wrote:My point was that if you say 272, you could mean the 272/272 OR the 272/284, which several Zone contributors use... why only compare the two extremes?
why dont you ask the man who posted the question instead of me? i aint comparing nowt mate, the question was which is the better cam between the above two, i gave my opinion and your entitled to yours so if you have anything to contribute towards helping DIESEL who posted the question help him!!, cant really understand what the problem is, i personally have a 272 meaning a 272/272 and obviously if i was saying the other one (284) i would have written 284. how constructive is the conversation now??? :hammer: :hammer:
Diesel
Post Fri Jul 22, 2005 7:06 pm
:D HaHa :D
Relax People
TW166Y
Post Fri Jul 22, 2005 8:29 pm
:yeahthat: :cheers:
stappin
Post Fri Jul 22, 2005 10:25 pm
What cam would you recommend for an E30 325i for rallying?
TW166Y
Post Sat Jul 23, 2005 1:24 am
stappin wrote:What cam would you recommend for an E30 325i for rallying?
This cam has 288 degrees duration and 11.4mm lift. This cam is not really a good choice for "street" engines. It makes very good power, but will affect the idle quite a lot. Great for track cars with higher compression and injection mods. this is a must for rallying dude :thumb:
stappin
Post Sat Jul 23, 2005 10:51 pm
Do you loose all the low end grunt? Cause you have to think I need accelleration I need it from low down and not fussed about top end...
TW166Y
Post Sun Jul 24, 2005 2:01 am
if you want bottom end grunt dude, get your self a diesel crank on it and chip it up etc... watch the ummmffff then :wink:
