Central locking help
Chris36
Tue Jan 13, 2009 8:49 pm
Hi guys wonder if you could help me........I have a 4 door 1991 E30.
My central locking has packed up by key & remote. I can unlock and lock all door manually so not the end of the world. I cannot however lock the drivers door, but I can unlock it. I have done the red/black wire trick - it did nothing for me.......what next?? Thanks
Tue Jan 13, 2009 8:59 pm
Pull out the locking ECU, and check (with a 12 volt bulb) whether there is power across the red/black and brown wires.
Chris36
Wed Jan 14, 2009 9:51 am
Brianmoooore wrote:Pull out the locking ECU, and check (with a 12 volt bulb) whether there is power across the red/black and brown wires.
thanks, where is that ecu? is it the small black box behind the speaker?
If so do you just pull it out?? thanks BTW
austin360
Wed Jan 14, 2009 2:25 pm
yea its on driver sidebehind speaker prob full of water shorted it out
Wed Jan 14, 2009 8:01 pm
Locking ECU is mounted on a triangular metal plate, which is fixed to the inner sill by two self tapping screws. The heads of these screws are on the inner sill immediately below the centre of the speaker hole.
Unscrew the screws, pull out the small plastic plate under the speaker, and pull out the ECU by its wires, complete with the bracket.
