Any one done any grit blasting?
citizensnips
Wed Jan 14, 2009 11:21 am
Hi
i'm thinking about investing in some grit blasting kit to aide in the resotration of my car and was wondering if anyone had eny experience with it? questions are as follows
-best blasting medium to remove rust and paint (grit,soda.walnut shells?)
-i can't get the shell outside so it'd be inside, if i cordon off the area with massive tarps will it still get every where or mostly end up on the floor close by for sweeping up
- is it better/less tedius then a wire brush on an angle grinder?
pony2
Wed Jan 14, 2009 11:36 am
I set up a small blast cabinet, the biggest problem that you are going to have is getting a compressor with a big enough capacity to maintain pressure. You will need a massive tank and this may mean you require a compressor with a higher rated electric supply.
I blast with Aluminum Oxcide, it is far quicker than using hand tools as the grit gets all the hard to reach places, it also goes everywhere and creates a lot of dust. You will also need a filter regulator which removes water and oil from the air supply.
Speak to any suppliers and they will explain the sort capacity required for your scale of operation.
Maybe try:
Shot Blasting Supplies: 01909 530 107
Hogg Blasting: 0191 415 3030
citizensnips
Wed Jan 14, 2009 11:43 am
cheers
already got the filter regulator and massive compressor so half way there :D
cabinet would be tricky as its the chassis of the car but sounds promising, cheers i'll give them a ring
darren1200
Wed Jan 14, 2009 5:32 pm
I use kiln dried sand from b and q costs about £2.50 a bag, spray it all over the garden, and after a couple of days it washes it self away lol
