pic request.. center console gauges
jbh
- Hartge Crew
as above looking for pics of center console gauges.. any one got the hartge style pod ?
adit
there's a picture from your previous guages post jb, under E30 chat, just bumped it up. i still have these sets available
shedrool83
Only thing i can find atm mate lhd model and poor pics.
http://cgi.ebay.com/ebaymotors/BMW-E30- ... ccessories
Btw how do i make the link say clicky or the likes
Cook318IS
bmp design do them too http://www.bmpdesign.com/catalog/modern ... tation.pdf
BadDave
I think you'll find that the ones in the links are for LHD cars
The BMP centre dash vent one should work though
jbh
- Hartge Crew
im wanting somthing like this but for rhd im wondering how hard it would be to get made up or if any one does them
Forsman
That is for LHD.
BUT, what's the difference in these products? Would someone tell me?
That is for LHD.
I would have a crack at making something like that myself - cut some MDF to fit, cover it with leather or vinyl - the trick will be hiding the fixings where you screw it to the console - but should be quite easy if you do it off the car.jbh wrote:im wanting somthing like this but for rhd im wondering how hard it would be to get made up or if any one does them
Back in the day I made a similar mounting for extra gauges in my Mk1 golf
jbh
- Hartge Crew
I've been thinking along they lines as well ive got a spare center console that I'm going to use as a test bed. my dad suggested getting my brother to make it up out of a bit of sheet metal then getting it plastic coated but not sure how that would look as I'm trying to keep it looking oemcapri_rob wrote:
Good luck with it mate - you never know - if you do a good job you might be able to start making and selling em to other Zoners !
As for the VDO gauges you can usually pick up the 3 you need from and Audi Coupe quite cheap - not sure whether the senders are interchangeable though and you will normally need a T-piece if you want to keep the oil light on the dash working as well as the Oil Pressure/Temp gauges.
cliffybabe
- Powered by Nelly
Kos & Dips did get these sort of holders made up at one stage and there was a group buy done, PM dips see if he can help
jbh
- Hartge Crew
ive got the guages and the holder that sits inplace of the ashtray but would preffer the style above ive also got the senders fitting them shouldnt be a problem
cliffybabe cheers for the info ill pm dips and see what he says
