4" custom subwoofer, 1st build now working with video!!
secondtimelucky
Post Sun Jan 04, 2009 6:41 pm
Well i just finished off the surround and fired one up.... Stuuuupid amount of excursion and low bass for a 4"er winkeye will get some vids up when i can figure out how in 3gp format but for now, heres a few photos :D
Wanted: Any old component speakers, complete or separate parts, let me know what you got :D
roley
Post Sun Jan 04, 2009 10:51 pm
looking good mate i want to know what they sound like so i can commission a set from you :D
secondtimelucky
Post Sun Jan 04, 2009 10:57 pm
Bit rough around the edges (and everywhere else !!) but they work a treat, re-doing te rubber surround as we speak though cos the 1st one was restricting cone movement winkeye and iv told you before, only one set being made and theyre for me!!!! lol unless you can find me the bits :D
roley
Post Sun Jan 04, 2009 11:02 pm
i am sure i can locate the bits i would just speak to bailey winkeye
Post Sun Jan 04, 2009 11:04 pm
secondtimelucky wrote:Well i just finished off the surround and fired one up.... Stuuuupid amount of excursion and low bass for a 4"er winkeye will get some vids up when i can figure out how in 3gp format but for now, heres a few photos :D
WTF!!!!!!,
secondtimelucky
Post Mon Jan 05, 2009 12:09 am
Yes rav thats a 100w/rms 4" sub :D
Flozman
Post Mon Jan 05, 2009 12:16 am
I admire what you have done, but its not pretty.
secondtimelucky
Post Mon Jan 05, 2009 12:20 am
Flozman wrote:I admire what you have done, but its not pretty.
Cheers bud, its only a first build atm, to see if the theory would work, and it does lol. Iv already started tidying them up now, but the ridged rubber surround will be staying :D
secondtimelucky
Post Mon Jan 05, 2009 12:54 am
And a short video of the excursion before fitting the rubber surround winkeye
miniblob
Post Mon Jan 05, 2009 9:39 am
You gonna be using it free air (just on the back shelf) or are you going to box them somehow??
As said, not pretty, but who cares what they look like!!! Do they actually sound any good???
327 Touring with bass!!!
secondtimelucky
Post Mon Jan 05, 2009 10:54 am
Having trouble lining up the surround atm, but the bass is there, just a little bit 'noisy' instead of clean bass. They will be boxed up eventually, one running in an old Creative pc sub box atm and its quite worrying the amount of bass coming from it :D winkeye will probably go bandpass when theyre finished though :D
sati
Post Sat Jan 10, 2009 4:16 pm
want to do sumthing with an 15" driver? it was a jbl gt4-15. got magnet and basket rest is histroy.
dazleeds
old skool raver
old skool raver
Post Sat Jan 10, 2009 4:24 pm
im sure my jbl studio monitors are 4"
sound nice n crisp with enough punch to liven up any tune :cool:
then theres the pair of 12s under the deck table :twisted:
www.oldskoolfantasy.co.uk
dazleeds
old skool raver
old skool raver
Post Sat Jan 10, 2009 4:25 pm
The JBL control 1's i use have 4" bass cones i think
thats em i have same
miniblob
Post Sat Jan 10, 2009 5:59 pm
Pretty impressive for such small speakers!!!!! I do like the proper jbl stuff!!!
Got a pair of SF25's with 2 15" drivers in each too!!!!!
sati
Post Sat Jan 10, 2009 6:03 pm
jbl's pro audio deparment is a lot better then there car audio , there gti range of sub's cant take the beat they claim they can.
secondtimelucky
Post Sat Jan 10, 2009 6:09 pm
Sati: wouldn't mind trying bud :D 15" would be a mission and a half to get under control :D winkeye so has the rest of it (ie coil, suspension, and cone) been removed or just fubared???
sati
Post Sat Jan 10, 2009 6:21 pm
well had the sub in sealed box, rms of sub was 250rms but was wired to an 500rms amp and it lasted for 1day before it sourround gave up then coil/former. so its just the basket and magnet which is removable i think 6 screws. the magnet got sum weight to it 2x40oz i led to belive, iam in rewiring my gt3-15 were the tensile leads gave up. so in the car is a cheap £30 12" sony explode 380rms on the same amp and it takes it fine. not given up yet, tryed blowing it (maxed out volume, gain , bass boosted +12db, headunit bass on max) and it was maxing out but still play's fine. so looks like sony anit as bad every says they are.
secondtimelucky
Post Sat Jan 10, 2009 6:39 pm
Yeah but those sonys have a stupid peak power rating like 1200w so your still nowhere near killing it IMO
On the subject of the 15" i wont be trying that for a while as iv now started another project... Getting a good full range sound (including bass winkeye ) from a 2" cone :D will try and post a vid up later on of these new ones up and running :D
sati
Post Sat Jan 10, 2009 7:05 pm
well i will wire it to my orion d5000 1000w rms at 4 ohm or 2500w rms at 1 ohm winkeye iam sure it will put it to sleep for good. full range from an 2" thats 20hz - 20,000hz your on about.
secondtimelucky
Post Sat Jan 10, 2009 7:44 pm
Well, i say 'full range' like a similar sound to a 5 or 6" two way co-axial speaker in-car, so i suppose 'broad range' would be a better term. Il be happy if i can get 80hz up to 20+Khz
sati
Post Sun Jan 11, 2009 10:02 pm
a 2" sub in bandpass box! now thats sumthing! going to be tricky to make a bandpass box as its so small , wat about a folded horn design ,lol
secondtimelucky
Post Sun Jan 11, 2009 10:50 pm
na na na bud, the 4"er is going bandpass, the 2" will be in a sealed enclosre winkeye
sati
Post Mon Jan 12, 2009 1:13 am
lol, how about a recone kit from an orion hcca subwoofer? rated at 2k rms will take 5krms before it goes. an 1 ohm 6" sub with silly x-max ,lol time to mess around with an old 4" kenwood, and an 12" jbl
