e36 engine
damoe30
Post Tue Dec 30, 2008 7:07 pm
will a engine out of a e36 318is fit in to a e30 318is..or do you have to cange any ting over..and is there 2 different types of engines in the e36 model...tanks for the help..
odbod
Post Tue Dec 30, 2008 9:04 pm
You need to make sure that you get the 1.8 engine (M42) other wise it's alot more work if you get a 1.9 (m44). in any case you'lll need to swap over manifolds, probably rocker cover and sump. Also swap anything else that looks different to be sure it'll work.
rix313
Post Wed Dec 31, 2008 3:51 pm
All that needs swapping is the inlet manifold, one or both of the engine mounts, oil sump.
Think thats all we did with ours. Go in nice :)
Alburglar
Post Sat Jan 03, 2009 9:39 pm
Do you use the e30 m42 loom and e36 m44 ecu - or do you have to swap to e36 loom too?
M42 - rightness! with proper 4.27 LSD
GrindCulture
Post Sun Jan 04, 2009 1:44 pm
As far as I'm aware, the sump needs swapping, which means the front pulleys will need to be swapped in order to aviod the pickup pipe and dipstick too. The inlet manifold can stay, but the E30 item is often considered better. I think the exahaust manifold will need to be swapped also.
O/T Alburglar where did you get your slipper from, that's exactly what my car needs!
Not in E30s any more :(
toby
Post Sun Jan 04, 2009 6:13 pm
Alburglar
Post Wed Jan 07, 2009 1:57 pm
GrindCulture wrote: O/T Alburglar where did you get your slipper from, that's exactly what my car needs!
Searched for a year and nothing came up, then ended up Buying one from a Guy off here -rare as rocking horse shite I'm afraid.
odbod
Post Thu Jan 08, 2009 1:18 pm
Alburglar wrote:Do you use the e30 m42 loom and e36 m44 ecu - or do you have to swap to e36 loom too?
I used the E30 M42 Loom and ECU.
You don't want an E36 M44 system as the engine and wiring is different, you could use an E36 M42 system (upto 1995 ish) and run all the E36 stuff, DISA inlet, Lambda probes and knock sensing. I've got an E36 loom and sensors, inlet etc. and tempted to try it, but looks like lots of wiring. You would need to use a non EWS (security) ECU or get the ecu un-locked.
