Rear 6x9's in a E30
forzaMC
Ive just recived some 6x9's for my treasured E30, the speakers are really deep, but the clearence in the back of the parcel shelf seems tiny, anyone else had this problem, any soloutions.
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Either cut the metal under the parcel shelf or build up the height on top of the parcel shelf with mdf.
parksie
Mdf is the way to go, You needa 4ft strip x 15 inches wide ( approx ) if youre handy with the jig saw ,then no probs, use the speaker templates then cover in a greyish material available from most accesory shops and the jobs a gudun
Adam318i
If you want an idea of the MDF spacers then here they are in the back of my car.
There 4 x 18mm MDF rings glued together then painted black. Do the job nicely and dont look out of place.
I got mine from a local ICE shop, although you can buy them online, just do a search in Google.
Hope this helps.
Adam
Hope this helps.
Adam
I love my Rice!
forzaMC
Cheers Guys,
Will try the MDF
Will try the MDF
DanJones
I also used mdf....it was an easy job and looks really good now. more sen sensible than chopping away at the metal i think
Cotty
- Hartge Crew
I got some off cuts (1/2 inch thich) of MDF trimmed to just bigger that the speakers, used the template that came with the speakers and cut the hole out with a jigsaw. Sprayed them mat black and bolted the whole lot through the rear shelf (metal as well). Sounded fantastic.Taylor325i wrote:Either cut the metal under the parcel shelf or build up the height on top of the parcel shelf with mdf.
