M50 turbo touring nearly finished!
Ant
Retired Team Member
Retired Team Member
Tue Jul 08, 2008 8:03 pm
James, if your intake temps are too high, given the large frontal area the IC occupies I strongly suggest a larger turbo( compressor and turbine A/R ) at least.
if the existing GT30 is out of it efficient range,it will just pump heat, nothing you add downstrem will affect the charge temp to a great extent.
have you measured temps before and after the IC ?
one day I'll make the BBB meet and come kick your tyres dude :thumb:
james3320
Tue Jul 08, 2008 10:15 pm
Ant wrote:James, if your intake temps are too high, given the large frontal area the IC occupies I strongly suggest a larger turbo( compressor and turbine A/R ) at least.
ive only looked at the inlet temps on the laptop during mapping, was up to 60degrees most of thr time and shot up as soon as it went over 1.4 bar,
im thinking about a bigger turbo but this one still seems to have more to give? small increases in boost are making big differences in power, the engine really responds well, the intercooler has got a large frontal area but its only 40mm thick and some of the flow is restricted by the bumper,
also the airfilter needs movin as its pulling in hot air from the engine.
what turbo would u suggest? probably a holset! winkeye
1an
Tue Jul 08, 2008 10:25 pm
looks abit of a weapon,
what about one of these
e30_Turbo
Boost Junkie
Wed Jul 09, 2008 8:53 am
James,
I spoke to a GURU of all things e30 M50 turbo, he said "clearly 451 bhp is borderline on most GT30 compressors as they usually have only a 53 mm compressor inducer. As an example a Holset HX35 usually has a 55 mm inducer, and probably performs better still due to most GT30s are sold with single entry turbines and no map width enhancement in the compressor housing inlet."
So it's time to.....
Fit one of them Holsets baby!
Will pop over one night and sort through them with you :D
Morat
Wed Jul 09, 2008 12:38 pm
Too much is never enough :)
gogogo!
kr1s23
Fri Jul 11, 2008 4:21 pm
ah mate.... that looks beautiful... certainly doesn't look out of place under that bonnet ether and i love how someone is still willing to put time and effort into a conversion like this, i love turbo's, especially the sound of a dump valve but since i had my 'polo g40' i'v bin thinking more along the lines of a supercharger conversion for my e30 318is, its actually got a '96 compaque' engine init which i think is the same as the original 'is' lump (correct me if i'm wrong) but i'm still unsure wat conversion to do, if you don't mind me asking wat kind of cost has your conversion cost you mate? bearing in mind i'm a mechanic by trade and i'll do the conversion myself....
zaust
Zone day release
Sat Jul 12, 2008 7:25 am
Wow. That is some work gone in to that. Want to see it moving for real.
M30 Tech 1 Touring on gas.
benjy
Sat Jul 12, 2008 9:00 am
I am officially jealous! Looking good, and 450bhp aint to be sniffed at! 8O
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
BigBavarian
Sun Nov 30, 2008 9:49 pm
Hows the building going james?
Richard
james3320
Sat Dec 27, 2008 11:29 am
e30_Turbo
Boost Junkie
Sat Dec 27, 2008 2:08 pm
You not fitted it yet? winkeye
Turbo-Brown
Boost Junkie
Sat Dec 27, 2008 6:01 pm
Oooooh, how much work's involved in fitting rear coil-overs? :D
Take it the towers need reinforcing do they? :)
james3320
Sat Dec 27, 2008 6:41 pm
You not fitted it yet? winkeye[/quote]
now making a new tubular manifold will be on there soon!!
james3320
Sat Dec 27, 2008 6:43 pm
Turbo-Brown wrote:Oooooh, how much work's involved in fitting rear coil-overs? :D
there universal gaz coilovers, the towers wernt reinforced but im going to now im putting a roll cage in, will incororate it in to them!
Zizzle
Sat Dec 27, 2008 6:46 pm
WOW....!!! Thats Lovely!
BigBavarian
Sun Dec 28, 2008 10:46 am
Good work james, that rear axle looks nice! and the size of that turbo... should be quick
Richard
Daf318is
Sun Dec 28, 2008 5:47 pm
And there's me getting excited about almost finishing my stock M50 conversion!!! :mad:
If looks are anything to go by that's gonna be fun winkeye
Daf
Andy325i
Mon Dec 29, 2008 12:38 am
Awesome!!!!! I can't wait to see this in the flesh!
Andy
Mon Dec 29, 2008 10:09 am
I think you could have got a bigger turbo at least... 8O 8O :twisted:
Wed Mar 18, 2009 6:43 pm
What's the latest with this beast then?
