Mtech 1 kit??
GoldenArms
WILL A MTECH 1 KIT FIT ON A FACELIFT G REG 316i
jbh
- Hartge Crew
it can be done but its a lot of work
zaust
- Zone day release
GoldenArms
Forget that then . .cheers for replies.
back bumper is fairly simple but for the front you need to change the valance for a pre-facelift one I have all the things needed to do this if you want them
zaust
- Zone day release
Front bumper, valance and skirts are the easy bit fella, Just a few bolt's.e30topless wrote:back bumper is fairly simple but for the front you need to change the valance for a pre-facelift one I have all the things needed to do this if you want them
Rear bumper is why you need the angle grinder and wealder, As the length's of them (sides) are very different + the rear metal valance get's in the way of the tech 1 valance and stop's it fitting, Due to it sitting lower and also not even nearly fitting over the side's of the valance either.
The_Diddler
- Love it up the more door !
