BOOT LEAK IN MY NEW TOURING
bazman
Thu Dec 11, 2008 12:54 pm
Hi all,
Had a 3" squareish hole in the left hand side storage bit on my touring where it backs onto the wheel (if you get me) which i got welded up by my local garage yesterday, trouble is its still filling with water when i drive it. Are these prone to leaky windows or other such trouble please? Cant see where its coming in.
Thanks in advance,
Bazzo winkeye
"Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life." - Terry Pratchett.
Morat
Thu Dec 11, 2008 1:16 pm
It might just be the rear wash wipe, have a look at the bottle/pipes while someone presses the button.
reggiebaby
Thu Dec 11, 2008 7:15 pm
check your light seals thats where mine were letting water in
had so far e30, e34, e30, e39
bazman
Thu Dec 11, 2008 9:31 pm
thanks chaps, cant see a leaky from the wash wipe but its wet round the light seals... :cool:
bazman
by the way morat - snap, mines identical to your sig pic :cool:
KimH
Sat Dec 20, 2008 6:51 pm
My Touring had the same problem which turned out to be water chanelled down from the roof coming in where the big vent behind the bumber had become loose. I sealed it in place with some Silicon Shower Sealant to fix the problem.
Morat
Sat Dec 20, 2008 7:18 pm
White tourings rule :)
toby
Sat Dec 20, 2008 7:20 pm
Rear lights often leak. You could try just tightening it up or removing it, cleaning the sealing area and refitting.
Edited: plus adding new seals.
