Group buy - 318is or Rieger front spoiler 'add on' splitters
Enter a group buy or look here for zone discounts
Thu Dec 11, 2008 4:51 pm
well it's here,,,i've now fitted it,,,although not as straight forward as i'd hoped...
i have a good over hang ,,all equal length...but to achieve this it had to be carefully measured,
gripped in place with moley's,,in two places,,,,measured again,,,adjusted,,measured..,and a final measure check
then drilled and fixed with the v,nice self tapping bolts supplied...the very outside of the splitter doesn't go flush with
the outside of the lip spoiler,,,,it losses it's line right on the end of the return bend,,,it was getting dark so not the best pic to explain.....but it's on now,,,
anyone else got theirs yet,,, 8)
Dan320is
Thu Dec 11, 2008 5:01 pm
Lightened your pic for you, will post a pic of mine shortly (not on the car yet though as its in storage).
Thu Dec 11, 2008 5:03 pm
cheers dan :wink:
Dan320is
Thu Dec 11, 2008 6:19 pm
Here we go, not sure where/how to mount it though.
Firstly this way with the ends meeting, creating the largest amount of lip out front. And the lip disappears nicely. It shows more than the 1".
Or this way, mounted further back leaving less lip and I would have to trim the ends. And the lip disappears sooner.
Thu Dec 11, 2008 7:27 pm
i fitted mine,,,with about 1 - --1and a quater inches,overhang,,,or,i thought it looked too big :?
i'll have another look at it tomorrow,,,,
Dan320is
Thu Dec 11, 2008 7:34 pm
Mine look like they are probably the 1.5" versions.
Thu Dec 11, 2008 9:37 pm
i thought that,,but more like a 2 inch 1 :? i'm not bitching realy,,,i'm still happy,,,but then again i allways am...
leftcoaste30
Thu Dec 11, 2008 11:39 pm
Thats wierd yours is so large. I know I sent out a 1.5" rieger cuz one of them was, but the rest should be 1". I wonder if I just screwed up and forgot to cut the backs off of those two... I'm mystified right now about that, I checked them all before they went out to make sure they were all the same size.
What about trimming a little bit and then putting it in the middle of 1" and the 1.5".
leftcoaste30
Fri Dec 12, 2008 7:43 am
Mk, thought about this a bunch this afternoon. Put it around 1 1/4. I know mine's just over 1.5 on my car, and its the 1.5 version, so I know its not exactly 1" on those. I'm gonna throw a disclaimer on, sorry about that, let me know if its a huge issue. Dan, if you do like magpie, it should be all good. And with the ends, to get them so that there's a bunch of bolt surface to bolt the edges, if you pull in your lip since its a softer material to get it to work there, it should be all good and it will set itself back out when you mount it on the car. Also, if any of you need more help, just let me know and I can get you my number or talk online if any of you have either AIM or MSN messenger.
Also figured i'd let you guys know, I talked with a friend who has access to a waterjet, and I think y next runs will be with a waterjet cutting to make it more exact on all of them and I can get the edges all perfected. Just letting you guys know for future reference. This was the first huge order, so now i know about some of the issues and irregularities.
essexboy
Sun Dec 14, 2008 9:55 pm
i've just had a look at mine and when i put it so its neat around the edgeswith none sticking out the back its coming out a 2 inch lip at the front :?
leftcoaste30
Mon Dec 15, 2008 7:17 am
So its flush with the back and its 2" from the front most part of your lip to the lip on the splitter? Just curious cuz yours is based exactly on what my rieger is and I have that right infront of me and its 1.5" Is yours a real rieger? Just curious cuz its not adding up to me.
Mon Dec 15, 2008 1:53 pm
how do you make a pic lighter,,,or will someone do it on this pic,,cheers
Dan320is
Mon Dec 15, 2008 7:03 pm
There you go, just takes a second in photoshop.
Mon Dec 15, 2008 7:21 pm
thanks again, :D
Dan320is
Mon Dec 15, 2008 7:25 pm
magpie wrote:thanks again, :D
Are you pleased with yours? Pm me if you like.
essexboy
Mon Dec 15, 2008 11:00 pm
leftcoaste30 wrote:So its flush with the back and its 2" from the front most part of your lip to the lip on the splitter? Just curious cuz yours is based exactly on what my rieger is and I have that right infront of me and its 1.5" Is yours a real rieger? Just curious cuz its not adding up to me.
thats right the rear corners are all flush and in the centre of the front it sticks out a little over 2 inches i'll try it on the car tomorrow and see how it looks
OBs
Mon Dec 15, 2008 11:19 pm
I'm confused about all of this, why are all of these nearly 1/2" or 3/4" wider then stated?
I wanted a 1" one because I prefer the subtle look of it, and didn't really want to achieve the 'added on look' :?
Sure I can trim it down but then run the risk of fooking it up, and providing It cost a fair bit Its not something I was hoping to have to do...
Opinions?
Tue Dec 16, 2008 1:15 am
same here, not like you can use a jigsaw on it..and get a clean polished cut,, :?
leftcoaste30
Tue Dec 16, 2008 3:35 am
Sorry guys. For whatever reason they match up on mine. The rieger I know is 1.5", my rieger lip ha right on it that it is a rieger original, dunno if yours does, but this one does and it is exactly identical, so not sure how it grew an extra half inch on that one. The IS I'll for sure next time state its not exact, that's my fault, let me know if you have a huge issue with it and we can work something out, I'm glad to, as I'm sorry their not exactly as stated. It is wierd that you guys are having issues with them but the others in the same batch which are identical haven't had any issues.
leftcoaste30
Tue Dec 16, 2008 4:30 am
Mk, just talked with my dad, he had one idea on possibly figuring out this difference. Here's my personal one, which yes I know I took out some size from what you guys got, atleast I thought. I laid the splitter mounted on my lip against the wall. The splitter sits dead flush with the back of my lip so its flat against the wall on both ends. The distance from the wall to the center of the splitter is as pictured. Just wondering if you guys could possibly do the same on yours. Its not adding up personally to me why its this way, and i'm not out to rip you guys off, I really want to work this out and get this problem solved.
Brendan
leftcoaste30
Tue Dec 16, 2008 4:50 am
Here's the same done with the rieger. I'd appreciate it if you could try. Sorry for all the inconvenience guys.
Tue Dec 16, 2008 11:11 am
i'd have felt ripped off if i never received received it...
mine only sits flush at the back when two or more inches are sticking out the front,,
that is too bg,,unless i get it cut,,,what did you cut these with??as the cut edge is shiny,or polished
leftcoaste30
Tue Dec 16, 2008 6:34 pm
magpie wrote:i'd have felt ripped off if i never received received it...
Wanna measure it before you cut it. I wanna figure this out please, cuz I wanna help get these fixed. You guys shouldn't have to redo these if its my mistake. And I cut it with a die grinder w/ a 4" cutoff wheel. I believe they are shiny because of when OBs was sanding them...
Tue Dec 16, 2008 7:23 pm
i have a shape finding tool,i used it to get the shape of my door frames onto the flooring i was laying,,
if i do this it won't be till after xmas now as it is on the car,fitted with 1and eighth inch lip,but looses a bit on the bend return.but will do for now,i'm busy with other things like these,
