I think I've got all the gaskets, got a complete bottom end set, and a MLS head gasket. The head I'm using was the one I rebuilt for Brown which had all new gaskets anyway. No doubt something'll come to light though
I made the whole exhaust and manifold system for Brown using a MIG welder, you don't get the lovely shiny welds like with the TIG, but they're every bit as functional
I've had great fun with the car today!
Started off by making the necessary adjustments to the hub adaptor. You can see it screws onto the E30 spindle properly now! The tolerance on the bearings and spindles boggles the mind!
And so with a great sigh of releif, the hub can now be screwed on. Just need to make a locking mechanism as obviously there's no deformable collar with the new nuts.
So here's the offset adjusted wheel perched in it's new home:
I've obviously measured something a bit wrong at some point along the line as there's only about 4mm between the rim and the strut now! Not sure if that's gonna cause a problem but it's not too difficult to adjust if it does:
And now I need to order up the material to make new caliper brackets
Started work on building the engine today, I'd forgotten how long it takes to clean out all the threads and all that gubbins! Also needed to adjust the end gaps on all of the top rings by about 0.15mm which is tedious to say the least
Still, all the rings are gapped properly and assembled onto their pistons ready to go in
Gonna finish off cleaning the block and crank tomorrow and hopefully install the crank, rods and pistons!
