(I also managed to put a 2cm scratch on my front bumper reversing out of my pitch black drive
Took off wheels...= light steering? :/
rare
Ok, I took off all my BBS last night to polish them by hand and although the result was bloody good
my steering is now really light! All the wheels were done up tight. Bit odd? Any one got any idea?
Ritchie
Are you sure you put them back on in the same place? Sounds to me like you have put the front ones on the back, with the different tyres the steering will feel different.
rare
I did them one at a time just to make sure I wouldnt make that mistake. It is very odd. Its not exactly a problem though..the steering feels great lol
Martinaston
OH GOD
2 cm's how will you live with yourself
Sjoerd320i
that's not really an option mate as the rear tyres are mostly wider than the fronts , so the steering should get havier.Ritchie wrote:Are you sure you put them back on in the same place? Sounds to me like you have put the front ones on the back, with the different tyres the steering will feel different.
don't really have an idea what it could be
rare
I know mate, but its so gay when something like that happens. Because its metalic so it probably means the whole car has to be repainted
Ziggy
Where did you get that from?! 's true for *some* people, but most of us have got the same size all round...329iturbo wrote: that's not really an option mate as the rear tyres are mostly wider than the fronts , so the steering should get havier.
Ritchie
I think he maybe means that they wear flatter cos they dont turn like the front wheels?
jonz
maybe you got polish on the tread of the tyres
Ritchie
jonz wrote:maybe you got polish on the tread of the tyres
Sjoerd320i
yeah I know mateZiggy wrote:Where did you get that from?! 's true for *some* people, but most of us have got the same size all round...329iturbo wrote: that's not really an option mate as the rear tyres are mostly wider than the fronts , so the steering should get havier.
Martinaston
The tyre pressure should be the only difference
mrLEE30
Shiney rims turn faster!!!!! less air resistance see!!!
mrlee
mrlee
320Touring
couldnt be something as simple as the car's tyres were a bit flat before you cleaned the wheels, and you adjusted the pressure on them before you put them back on??
my 320i is sensitive to tyre pressures on the front (205/55/15) ie if its 2-3psi down the steering feels sluggish
